New Apr-26 beta now available
 1-4  5-24  25-44  45-48
568.25 In reply to 568.1
From Steph
At the first view "normal's problem" & 90° seems works! :)
More infos the 3/4 05 2007 :)
Bravo!
568.26 In reply to 568.25
Hi Pilou, that's great!
568.27
Fantastic! Text and helix tool! And I just tried out the curver projection, it rocks hard!
568.28 In reply to 568.13
Hi Michael
Feedback...
ScaleArray,FullScreen work fine, operated was my error (Pardon)
Problem with letters "aswz" only with shell-command
New Problems:
Offset-command---> Freeform curve, other point interpolation, a lot of kontrol points (image)
Blend-command----> Four like pages, three different results (image)
Best regards
Ede
568.29 In reply to 568.28
Hi Ede - yes generally the offsets will have a lot of points. I'll take a look and see if I can tune this up a little bit, there is something that I can try. But in general you can expect that the offset will be heavier than the original curve.
re: Blending - Blending is really intended to be used on an edge that is "open" - that is not attached to anything.
It will work on a joined edge, but it is pretty random which surface it will decide to take.
So to get more controllable results, select and delete that inside face before you do the blend.
Thanks for your bug reports!
568.30
Hi Michael:
Very good idea to add fonts to MOI
Best regards
Juan Galvan
568.31
I have been playing around with a Celtic Knotwork Font, I am having trouble with filleting edges, why will some sections not fillet? I am attaching the file.
regards Tim.
568.32 In reply to 568.1
I'm getting a weird display thing happening with these objects in the 3D viewport.
When I move one of them in the Z axis, it moves in the opposite direction in the 3D view port. I've tried re-setting the view ports... it still happens if I close the file and reopen it.
Jesse
EDITED: 29 Apr 2007 by JESSE
568.33 In reply to 568.32
Hi Jesse - normally that would mean that you've rotated around a bit too much over the top and you're sort of flipped upside down.
If that's it, you need to either rotate your view again over the top and flip over to be right-side up, or another thing you can do is hide everything and then do a reset.
If everything is hidden, then reset will go back to the very original default view. Normally doing reset will not alter your view angle but instead zoom out to fit to objects from that same angle.
If neither of those helps, please post the file so I can check it out.
568.34
WOW - and i just wonder how you made it Jesse
//Hep
568.35 In reply to 568.31
Hi Tim,
It looks like the problem pieces are ones with thinner sort of slivery pieces, like the top of this one here:
Compressed and small thin areas (also things with approaching shared tangents like this) tend to be a difficult area of calculation.
It will probably be a while before stuff like this gets much better.
In this case, you can get fillets on most parts of the object if you select all edges except for the top 3:
It is also possible to construct the fillets in a much more "manual" way, by separating the parts into surfaces and then working on things at a more kind of low-level individual surface level, constructing fillet surfaces and trimming the other surfaces to create holes, and then joining together the final results. That tends to be pretty difficult and time consuming though.
Some other CAD programs like SolidWorks do have a more powerful fillet engine on them, if you need to do a lot of somewhat more complex fillets like this, you may need something like that.
568.36
Thanks Michael,
I will see if I can avoid these corners,
regards Tim.
568.37 In reply to 568.33
Yep, that was it...It was flipped over.
I have a question; The new Hide button it seems to go against the convention of the other buttons because you
have to use to the Enter key to get out of it rather than click-off with the right mouse button. Would be possible to
keep the default function as before and use a key to invoke the alternate version?
-Jesse
Hep, the braid segment is made with a two rail sweep and a scale rail. In preparation before doing the sweep and arraying the object around the ring circle,
I projected the base rail curves to a cylinder that was extruded from the finger circle so that the bottom surface of the object
would conform to the curvature of the circle.
EDITED: 30 Apr 2007 by JESSE
568.38 In reply to 568.15
> Alltough I was also kind of hoping for support for the 3dconnexion navigation
> devices [I am known for my impatience, but I am working on it :) ].
It won't be much longer, they are having a seminar on how their SDK works on next Thursday, so I will probably watch that and start working on it then.
Oh yes! That would be amazing!!!!
568.39 In reply to 568.38
I was wondering..... with that device, the basic one that looks like a doorknob,
can you do mouse clicks with it, or is only for rotating, zooming and panning?
Jesse
568.40
rotating, zooming and panning. But you're also able to set function when you tipp on it.
I will never give this wounderfull thing away! It's unbelievebel how fast you could work with it.
Real amazing!
568.41 In reply to 568.37
Hi Jesse,
> of the other buttons because you have to use to the Enter key to get out of it
It should be working with right-click the same as other commands... Maybe you were right-clicking while still over the button itself? Right-click alias for "Done" works when you right-click over a viewport, not on the UI.
But I've tuned this up for the next beta so that you can also push the "hide" button again with either left or right click that point, as another way to show all objects.
568.42 In reply to 568.41
I guess I was still clicking on the button, not the viewport.. I'm still a little confused, though..it seems that it forces you to do an invert hide
before you can get out of the command, which isn't typical of a hide button
The other thing I noticed is that if you open a file that has hidden objects and go right to the hide button to unhide them and then you double click in the viewport,
you get the close dialog box, to save changes, discard changes or cancel. Is it normal? Maybe I've messed something up in my ini file...it's quite possible!
Jesse
568.43 In reply to 568.42
> hide before you can get out of the command, which isn't typical of a hide button
The invert is just temporary - it lets you specify what objects you want to show.
So for instance if you have a large quantity of objects hidden but only want to show 2 of them, the old way was pretty painful, you had to show everything and then re-hide the other objects again.
So the new way does a temporary invert that shows you which objects were hidden, and if you pick some of those and push "done" (or right-click or enter), just those that you selected will be shown. But if you want to show them all, push "done" without selecting anything and all hidden objects will be shown.
I realize that this adds some complexity to the hide command, and I was hesitant at first to make this change. However I decided it would be best in the long term to do it, because it ends up being just one additional click to get the old behavior of showing everything, and it provides pretty significant flexibility for more complex cases where there are more numerous hidden objects.
Let me know if it still seems weird after you have used it a little bit more. If it does then I will make an option so that you can revert it back to the "just always show everything" behavior.
> and then you double click in the viewport, you get the close dialog box, to save
It's normal - MoI doesn't really use double-clicks very much, what you did there was interpreted as 2 clicks.
The first right-click was the same as pushing "done" - this caused the hide command to exit and show all objects.
Then the second right-click happened while outside of a command - this is used to repeat the last command which in your case was "open". Part of the open command is to prompt for saving if any changes have been made...
If you want to show everything, just do a single right-click, not a double one.
568.44 In reply to 568.43
Thanks.... As long as there's a logical explanation for the way things work,
I can get used to them. :-) I don't need the old version of the hide button,
but thanks for offering. Usually, I just need to hide all the surfaces so I can see curves...
isn't there's a script for that? I'll have to install it again.
I don't mean to be a pain, but but I've observed another thing that seems unexpected to me,
but for all I know, it's probably logical and the way it's supposed to work.
I wouldn't do it intentionally, but if I use the copy and paste edit tool
and then use the hide tool, paste repeats with a click in the viewport and will not
cancel until a command other than hide is used.
Jesse
Show messages:  1-4  5-24  25-44  45-48
