More works done in MoI3D
 1  2-21  22-31
5679.2 In reply to 5679.1
I love that pictograms !!
...but i detected a "technical error" on extruded pastas..
Bucatini it's a kind of pasta with a -pipe-shape,so must have a inner hole!(name's translation means "little holes")
your rapresentation just show a common spaghetti
..anyway you are a Pro:bravo!
5679.3 In reply to 5679.2
It's not a technical error, there were printed so small you wouldn't notice the hole anyway ! :)
shapenoid.com stojan-voumard.com
5679.4 In reply to 5679.3
By the way they are in the new worldwide Kitchenaid catalog :)
5679.5 In reply to 5679.1
Really cool stuff DesuDeus, thanks for sharing! You're creating a lot of different styles of things!
5679.6
Nice work DesuDeus
5679.7 In reply to 5679.3
Shapenoid:
i joked on it...complimenti !
Stunning!
How are made the different tickness lines of the blender ?
What format in export? And what is the prog used for the Print?
5679.9
@Michael Thank you, I've got plenty more things to show but I can't until they are finished projects !
@Pilou Thanks, the lines are exported as AI and the thickness are tweaked in illustrator, the catalog is made in indesign and the pictograms are imported as illustrator files
5679.10
deleted
EDITED: 5 Jul 2014 by SAMUEL ZELLER
5679.11
Great images
I really like your render work also.
Seems the reuslt of some unbiased engine right? fry? maxwell? octane?
Do you have to tweek the lights, materials a lot in your render also?
5679.12 In reply to 5679.11
@Paulo Yes it's Maxwell Render
I was part of the Octane render alpha and beta too but I don't use it at work.
The materials are not complicated, it's just that the client want 100% the exact same color that is hard.
The lights are really simple and there's an HDRI for reflections.
5679.13 In reply to 5679.12
Great , I love your work and maxwell renders, I wish I could use it with modo.
I guess in your case you use it with C4D right? Do you think the stand alone version is very cumbersome when compared with maxwell for c4d? or max?
5679.14 In reply to 5679.13
@Paulo Yes I use the C4D plugin, standalone is not good when you do a lot of variations because you constantly export/import stuff
Thanks for your comments :)
Another thing I already showed previously on this forum made with MoI 3D + C4D + Maxwell
http://shapenoid.com/Golden-Dreams
5679.15
deleted
5679.16 In reply to 5679.15
..and what about the handle you posted time ago..? i think is related to this windows..
5679.17 In reply to 5679.16
@M-dynamics Yes it is, I've got 18 windows models + 5-6 different handles with different finishes
Can't show everything yet but there will be an online website where you can change colors and finishes on a 3D rendering...
5679.18
deleted
5679.19
deleted
5679.20 In reply to 5679.19
Really cool illustration style stuff!
re: shading artifacts, are you getting a normals tag coming through when doing your import? Are you using OBJ format or something else like LWO.
Usually those kinds of shading artifacts mean that the vertex normals are not coming through.
5679.21 In reply to 5679.20
Here's some parts that cause problems. I export either in OBJ Ngons or OBJ triangles with "avoid less than X" for loosing a bit of details in the fillets.
I import using default C4D importer. I get the normal tag.
https://dl.dropbox.com/u/44982094/normals.3dm
Show messages:  1  2-21  22-31
