Michael
 1-20  21
5672.1
Hello, Michael.
Your program is cool, just short of a couple of little things that keep it from being a tool for conceptual artist: 1) patch, when constructed, should have a snug fit to the neighbouring surfaces tangent and curvature. This is necessary for editing and restoration.
2) curves with edges should have copied the same degree as the original from which the copied, also if the surface formed by the curve profile of 5 degrees, which stretched along the Guide, the prjected line on the surface of which must have the same degree, and shaping. In short you need complete control over the geometry, because it is very hard to deal with errors. Offensively, When an artist is forced to conceptual design started at Moi 3d throwing and Rehan in CATIA are all just because of the fact that he needs just a normal form surfaces.
3) should be able to use blend's guides, and be continuous for the tangent and curvature, not only to surfaces of ribs which he builds, but also from the lateral (perpendicular) surfaces, such as patches with support for tangent constraint and curvature to the neighbouring surfaces, only here blend. It is very convenient and correctly, saves a lot of time, not to mention the fact that some surfaces could not be built without it.
4) rounding too raise questions, but their mistakes can be corrected just by yourself manually if the first 2 points will work.
Very nice your program, but it does nothing to be more functional, not worry about adding decent features will make it a little more difficult, it is not, I think artists will thank you if they do not have to alter geometry. Prior to that I've met, that many begin to nurbs modeling with Moi 3d, but after working a bit, pass away to other products, despite the ease and convenience of the program because many need a result. I am sure that if you make a normal control curves and surfaces not only patches on a tangent and curvature, as well as normal operation with degrees of projected curves and forming surfaces, then your product will live long, competitors will be small. Now it is convenient, but it will be even and complete in terms of functionality, so that you do not need to look for another.
P.S. I'm sorry for my English, is Google Translator
EDITED: 26 Jan 2013 by DMITRIY
5672.2
I think you need a better translation to get your points across with less ambiguity.
Martin (2).
5672.3 In reply to 5672.2
Ok! I think I will need pictures to it and clearly and without ambiguity
5672.4 In reply to 5672.1
Hi Dmitriy, I definitely want to add in controls for maintaining tangency and curvature, it's something that I've been working on.
But some of your requests such as keeping a projected curve to be the same degree as the target surface are highly technical - please keep in mind that MoI is not meant to be a complete replacement for something like Catia which you mention which is in the neighborhood of $20,000 design software. MoI only costs $295 and it is not really feasible for it to replicate the functionality from a much larger and more expensive package.
Keeping MoI light and easy to work with is also a priority - it is not intended to make it so laden down with highly technical controls that it requires an advanced engineering degree and training courses in order to use it. So that's another area where it is largely different in target and scope from something like Catia.
So if you have very specific requirements, that's not particularly unusual that you might be needing to use MoI in combination with some other fancy software. That's one of the things that just helps keep MoI more streamlined and helps to retain its easy and fluid workflow.
However, I definitely agree that there are features that need to be added, in some of the specific areas that you mention particularly tangency and continuity controls and I am in the process of working on those. But I do not particularly see MoI ever becoming a replacement for Catia - like if you have the requirement of a projection of a curve having the exact same degree as the surface projected onto, that's a very technical detail that most users are not going to be concerned with and so something of that level of detail is not likely to be targeted for moi.
Thanks for the feedback! And I definitely agree that some of the areas that you are talking about should be included in MoI, they are somewhat finicky areas that take time to develop well which is why they are not in there quite yet.
5672.5 In reply to 5672.3
To avoid ambiguity, the bottom link to the video. There to show the design of patches and sweep and blend with the continuity and curvature of all surfaces:
http://www.youtube.com/watch?v=skDq_eBpdFQ
http://www.youtube.com/watch?v=xCLpWeN9AlU
http://www.youtube.com/watch?v=pscuHv8Ii7o
http://www.youtube.com/watch?v=SPVZQQCvpYo
Speed ​​and simplicity. If you finish the MOI 3D, making continuity functions in the network, and other tools, it will also cool
5672.6 In reply to 5672.4
Michael, thanks for the reply.
You do not quite understand. Maybe it's my English is to blame.
When I spoke of CATIA, it did not mean all of its functionality. I was talking about a small part of it for building surfaces. I agree that this is a high level of CATIA CAD software, but its complexity is not in the geometry modeling, but in a variety of different modules and the ability to automate everything. Well, if you can not project a line exactly, then okay. The main thing that has continuity in the network and guides when blend with continuity to other surfaces, and also the continuity of the sweep. Then it will be very cool!
5672.7
How do you like this idea: you leave it as is, but do the continuity and other tools, and sell more-and this one product. But for those who want more features you add more features to the zebra crossing to analyze the surface curvature, but bet the price is more expensive- and this is the second product, a class above. Thus you will cover all the needs of users. Your product will benefit not only budding artists, but also professionals in industrial design.
Personally I own version for students and it rests on a shelf, but willing to pay 600-1000 $ for a working tool. Why do people study hard CÁTIA merely for the sake of artistic modeling, her only function in other engineering tasks. Therefore, CATIA is so much worth ($ 20000)
I repeat that you have a good tool. Need to add some functions to become the undisputed leader among the programs of this class and favorite tool of industrial artist.
We wish you good luck and success in creating us a tool to our creativity. Thank you!
5672.8 In reply to 5672.7
great requests for the surface continuity features. One thing to add:
MoI is in a class "all by itself".....
There is nothing else like it. Nothing.
5672.9 In reply to 5672.8
A quick view of the history update in MoI, as seen in one of the Catia Video's:
5672.10 In reply to 5672.8
to BurrMan
"great requests for the surface continuity features. One thing to add:
There is nothing else like it. Nothing."
What do you say you say about this:
http://www.youtube.com/watch?v=6dkq9Q8gwLA&list=UUTvlWV6F8hA_mHSAfmxcuPA
http://www.youtube.com/watch?v=C4h9DJ3q6oA&list=UUTvlWV6F8hA_mHSAfmxcuPA&index=30
here on the Forum no fanatics, here are people who contribute constructively solve the problems with the tool, and are not satisfied with the battles and holivars. Do you have concrete suggestions for optimization? Michael me constructively and understood but explained what can and cannot be done, and your comment about anything.
I too like Moi, otherwise I would have here on the Forum did not write
5672.11 In reply to 5672.10
Hi guys, please let's not let things get out of hand with "flame wars" and such.
The main thing that Burr's talking about with "nothing else like MoI" is not about just some set of features or list of capabilities but more the overall focus on ease of use and fast fluid operation.
It's got a lot of capabilities. But the big difference would be - try to sit a person who has never done CAD before down in front of that software and down in front of MoI and then see which one the person can actually figure out how to use! :)
That's the big difference with MoI - there is a huge focus in MoI on making the tools flow well and have the UI stay out of your way - it's the kind of thing that involves lots and lots of little details in the UI and so it does not show up so well on some itemized list of features. This is the area where yes it is not any exaggeration to say that there is nothing else like MoI.
The examples that you have been showing have screens totally full of tons of buttons and require a lot of effort to learn. It can be difficult to really appreciate how arcane and difficult to use many of the things you are showing are for a first time CAD user to try and figure out.
This ease of use factor is not something that you can understand from looking at a demo video that shows an expert demo jock who has spent years refining their skills with the software... It's similar to watching a video of an expert artist pick up a pencil and draw a great illustration. What you're seeing is more the result of the artist's hard won skill and not something really built into the pencil very much.
EDITED: 26 Jan 2013 by MICHAEL GIBSON
5672.12 In reply to 5672.7
Hi Dmitriy,
It's a great plan! But before getting too excited about it, please do not forget that I'm only just one person working on MoI and that puts quite a bit of limits on what I can actually get done.
I think in the future it might happen that there would be some kind of "basic" and "pro" version, but it's probably quite a ways off. It would only be very easy to do that once I could sort of peel off the basic version and call it done forever and not really worry about developing it much more - that's because trying to maintain multiple streams of active development across multiple versions adds complexity to the development process itself.
Right now there are still a lot of things that I want to improve even at the "basic" level, and so this kind of separation into 2 versions is quite a ways off I think.
Actually I've found that there is a strong class of professional users who appreciate the fluidity and speed that MoI gives you in drawing basic shapes.
I think it's a big misconception that professional designers are always 100% involved with making organic high continuity swoopy shapes all day every day - sometimes it's nice to just be able to draw things very quickly even if the results do not have perfect continuity. MoI is useful in such a capacity right now. There are plenty of people who use it just for 2D curve drawing for example...
Anyway that's the main reason why MoI's user base does already include a wide variety of professional users in addition to beginning artists already.
But certainly some more features involving continuity would be welcomed by a lot of different people, that's why I've been working on that area and it is definitely an area that I want to improve. But continuity can be a finicky area in general - often times just having continuity does not automatically mean things look nice if the curvature is bunched up in a small area and not distributed very evenly.
5672.13 In reply to 5672.11
I was forced to work in CATIA, before that made models of the Moi, so I will say that the MoI is similar to the module in the CATIA which is called Freestile , it is designed for industrial design, and in the Moi and Freestile convenient to work with the Moi and in Freestile few buttons. Here we have a picture of the number of all the buttons of this module Freestile note here the key is not only modeling , and analysis, so the buttons for modeling, still smaller than in the picture:
Size: 62.5 KB, Downloaded: 124 times, Dimensions: 493x649px
5672.14 In reply to 5672.13
Hi Dmitriy,
> in the picture:
That's a good example of a UI that's really quite difficult for a beginner to get started with - just lots of pretty small icons everywhere, no text no labels no labeled categorziation...
Just icons themselves do not convey enough information for a beginning user to really have much idea what they do - when a beginning user browses over that screenshot that you just posted, they don't think "oh that's the function I need", it's more like they're looking at a bunch of indecipherable Egyptian hieroglyphics and they don't have a translation for it... ;)
That UI can work ok for a trained user who will invest many hours of studying and taking classes in order to learn how things work but it's quite baffling for other kinds of users who do not have a whole lot of time (and $$) to invest to go to training.
The level of confusion that a UI like that presents to beginners can be quite hard for an expert CAD user to relate to very well.
5672.15 In reply to 5672.13
MoI from CATIA_Freestile distinguishes the addition of a small number of functions for convenience and simplicity they both are equal, it is easier than Solidworks and other CAD.
You are a thinking man, take a look, compare for yourself... I will no longer post on this topic , I am glad that you yourself are working on some of the issues, I hope that I and my colleagues and friends in the near time will be able to get moi with shelves and start to use for work. And really hard to use this Alias.
Thank you all.
5672.16 In reply to 5672.13
And just to put things in a bit more perspective - MoI is really focused much more on the basic concept of constructing models from 2D drawn curves and using booleans to cut pieces with another, that's the most fundamental area where NURBS modeling is particularly strong in.
Things that involve curvature continuity tend to be more in the realm of organic shape modeling - NURBS modeling becomes a lot more difficult in that area and often times those kinds of models are really better done in a polygon modeling package rather than any kind of CAD program at all.
The stuff that you're talking about is all much more in that realm of semi-organic type modeling - the initial main focus of MoI is not really strongly in that area, like I mentioned it's much more in the overall concept of using 2D illustration techniques to construct 3D objects. This works great for a wide variety of mechanical like shapes. For more organic swoopy shapes I mostly assume that most people are going to create that in a poly modeling package instead of in CAD at all, that's basically why there is not really all that much focus on continuity controls in the earlier stages of MoI's existence.
Some people seem to think that "concept modeling" is only about making swoopy organic melted looking things, but I think that's a very narrow view - really anything that allows you to do stuff quickly and easily can help to express "concepts" as well - just getting an idea from your head into a model is part of that, it's not like it's not allowed to be a "concept" if it doesn't have perfect looking Zebra reflection lines.
Hopefully this may explain a bit more about the overall design strategy of MoI, particularly as to why I've focused early on more on 2D construction techniques instead of areas that require more in depth comprehensive knowledge of NURBS modeling in order to be effective with them.
Like for example what you were asking about in your original post about keeping a projection as the same degree curve as the surface that it's on - that require a whole lot of very specific and advanced knowledge for someone to really even know what that means - that's very much against the overall direction of MoI. MoI is trying to bring some of the strongest areas of NURBS modeling (2D construction techniques and booleans basically) to be useful to people without requiring them to have an advanced math or engineering degree to understand how to do everything.
As time goes on I am trying to fill in more and more feature areas for the sort of traditional "Industrial design" swoopy concept model stuff, but I am approaching it carefully because I don't want MoI to become some kind of cryptic high learning curve and unapproachable software as is typically the case for such things.
5672.17 In reply to 5672.15
PS. I have not spoken about the icons and interface, but the number of teams that their little space. the Moi interface is that it is necessary, it should remain that way. I spoke about the features of the tools: tools moi similar to each other on the tools Freestile , only function is a little lacking.
i am sorry, it's all, I will not bother
5672.18 In reply to 5672.13
Sorry DDP but MoI interface = 30 icons with words to get ya started plus self explanatory texts on tabs to delve deeper into the toolset where a similar layout of clearly labeled buttons await with icons. The screen you show there is over 50 icons with no visible clue of where to start. As Michael has said, the idea behind MoI3d is speed, ease of use, less clutter, logical fluid modelling sequences that just flow from one function to the next.
I came from a long and arduous root ... My history was Pen & Paper - AutoCAD - 3DS Max - Rhino & VRay - MoI3D - Cheetah and Shade, over the years I have spent thousands of pounds looking for software that functions in my little niche as a garden designer for the disabled and for wildlife, I thought I had met that with Rhino 3, but then better plugins meant i need to go to version 4 and that move introduced me yet again to whole heap load of bloated menues and hidden functions that were a nightmare to remember and still cost me hundreds of pounds to update and upgrade to just give me a financial loss and a major headache.
I have just spent money again on Shade and on Cheetah purely for render engines in OSX but they are sadly lacking from what i have grown used to. Trust me when I say this, I took to MoI like a duck to water, and it was so refreshing to be able to just sit and model things without having to rummage through a 1000+ page book to find a tool i needed, there really is nothing like MoI .... I can design my 2D curves for garden design work quicker then i could in any other package purely because of the power of MoI and its intuitive workflow that just works.
You are used to your CATIA and you are missing some of the functions that it possess, but please remember that MoI is a "designers" tool, it's there for those moments where you need to get something down quick before you loose that thought, Catia is a project development tool where things can go at a sedately rate where parts are manufactured to strict tolerances with lists of materials etc costs et al .... MoI and Catia are as different as a citroen 2CV and a Mclaren M1, they will both get you from point A to point B, but one will do so quicker than the other. MoI has the speed and ease like the Mclaren, but does it with the features and the cost comparison of the 2CV, purely because it's not Bloatware.
MoI is fast and fun and easy to work with, if that ever changes, then me and my cash will go elsewhere as soon as something else comes along that can replace MoI, and I for one hope that I reach retirement age before that happens.
Enjoy your MoI and your CATIA, it's nice to have input that offers potential insights to the future path of MoI, but accept that they are both tools designed to suit a particular audience ... You dont need to spend 20,000 on software to design a thimble when there is MoI3D available for almost 1/70 the cost and can probably model it far quicker and easier. Now if i was designing the latest 300 foot yacht that has people queuing to purchase at over a million pounds per sale, then I dare say I would then plumb for CATIA, but until that happens i am staying put :)
Martin Spencer-Ford
5672.19 In reply to 5672.17
Hi Dmitriy, I'm sorry if what I've wrote above has discouraged you, I was hoping to explain some of the reasons why some kinds of NURBS features like continuity controls have not been a focus for the earlier stages of MoI. The primary focus has been more on being able to build things quickly from 2D curves basically. It's more like "build a shape with some curvy elements (like some revolves and sweeps and such but not 100% completely composed of them) really quickly".
Probably this main initial goal does not really coincide with what you need to do, that's probably what makes MoI not quite suitable for you without some of these particular features.
I do definitely agree with you that more continuity controls would be helpful and it is indeed something that I am working on. I'm not entirely sure if it will get to the level that you need or not, there is a certain point of difficult to use functionality that just does not fit in with MoI's overall philosophy and direction.
5672.20 In reply to 5672.19
Not quite sure what i said that was so bad or sounded like some type of "Attack"... It wasnt my intention.
Oh wait.... A potential customer just called and wanted to see something. I'll have to put my MoI on my 25 megabyte USB stick and go to his office and get the job! He'll be blown away when i model it at his desk, right in front of him at his office, in about 7.5 minutes!
Anyway...
Show messages:  1-20  21
