Script request :)
All  1-4  5-10
5667.5 In reply to 5667.2
Ok, for the second one unzip the attached and copy the 2 files into the commands folder. That will then make a new command called Polyface available.
It works the same as polyline except when it's finished it will do the same thing as selecting it, running Construct > Planar on it and then deleting the polyline curve. So it will generate a trimmed face when it is finished instead of a polyline.
Hope this helps, looking forward to seeing what you're up to! :)
5667.6 In reply to 5667.5
so seems very interesting when you mixe that with your import OBJ object plugin
where object without double edges can't make a surface with the planar command in one shoot
5667.7 In reply to 5667.6
Hi Pilou, sorry I don't understand what the "without double edges" part means... ?
Back a while ago I did add an additional mode to that OBJ converter program, the original mode is that it converts one line for every edge in the mesh - the second mode is that it makes a closed polyline for every polygon in the mesh. That second mode is ready to be selected and converted to planar surface as long as the polygons were actually planar.
5667.8 In reply to 5667.7
yes but when original OBJ object has not double edges you can"t make in Moi in one pass all planar faces of the imported model
You have each line yes, but not all faces as separated faces so planar don't work in one pass
5667.9 In reply to 5667.8
That's not true anymore, there is now a second mode for the OBJ converter that will make one closed polyline for every face, instead of one line for every shared edge. It puts up a dialog that gives you the option between those 2 modes.
I think you're remembering only the original mode that it had and not the new one.
See previous post here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5135.5
5667.10 In reply to 5667.9
With many late! :=)
Yes i was on the original version, all is fine now!
Show messages: All  1-4  5-10
