Need some help to convert a solid work file.
All  1-8  9-15
5654.9
Hello,
Here are both designs in STEP format. The file size is much smaller with STEP. Hope these help.
EDITED: 8 Aug 2024 by OSTEXO
5654.10
Hello,
For some reason there are no models for the quilted top that is referenced, or perhaps the models are there but the linkage is not correct.
5654.11 In reply to 5654.10
Hey PaQ,
Just download the solidworks edrawings viewer:
http://www.solidworks.com/sw/products/free-cad-software-downloads.htm
It will open the entire assembly, and also give you access to dimension tools to inspect the geometry more precisely...
Good luck.
5654.12 In reply to 5654.11
Getting the dims...
5654.13
Hi all,
I've just tried 3DSync from Siemens PLM. It open, modify and convert a lot of cad format files. And, also, there is a trial free until may 2013.
No direct export to 3DM but you can use iges or step.
I'm using it modifying Solidworks files created by a client. It is very fast and useful.
Best, Giovanni
5654.14
Thanks guys, I'll check that !
Hi gbing, thanks a lot, that's very handy !
5654.15
OSTexo !!!! thanks you so much for the conversion, wonderfull !
Show messages: All  1-8  9-15
