Advantages of v3 for "meshing users"?
 1-4  5-24  25-27
5637.25 In reply to 5637.23
"So other than this "names with spaces" issue, does it look like that will do what you need?
Someone on the Rhino newsgroup could probably write a little script that would convert layer names to switch spaces in them to underscores."
Yes, this could be a solution. Is there a chance to get the "use style names" option for v2 too?
Visualisation for Designer and Architects | http://www.simulacrum.de
5637.26 In reply to 5637.25
Hi Micha, ok I've added that in for the next v3 beta.
It will be a new setting in moi.ini under [OBJ Import], called:
[OBJ Export]
WriteStylesAsGroups=n
You will be able to change this to say WriteStylesAsGroups=y and then you will be able to output the kind of files that I posted earlier.
By default spaces in the style name will get converted to underscores. There is another setting you can change to enable writing spaces AllowSpacesInObjectNames=y but you will need support for that on the Rhino side before that will work properly. Until then you would probably want to have some script in Rhino that will replace all spaces in layer names with underscores so that does not cause a problem with the names changing.
Sorry no, v2 is not really under active development now, v3 is where I'm adding new things so that's where this new feature will be in.
5637.27 In reply to 5637.26
Thank you. :)
Show messages:  1-4  5-24  25-27
