Inset question
All  1-9  10-17
5632.10 In reply to 5632.9
Good got it. And the last question, whywe have to extrude it?
5632.11 In reply to 5632.10
Maybe that works better with a volume for a curvated surface...
Wait and see the the Michael answer! :)
5632.12 In reply to 5632.11
good thanx)!
5632.13 In reply to 5632.1
Hi mir4ea, it looks like some kind of a bug in one of the shelling steps that Inset does. I haven't found out the specific bug yet but sometimes things with smooth boundaries can have the problem where one step generates a shape that is just very slightly not entirely smooth at its closure area and then if another step after that thinks that it's a sharp edge that needs to be extended and intersected and it is problematic to try to find the intersection on pieces that are nearly tangent to one another because they meet more at an area of overlap rather than at a distinct sharp intersection curve.
I'm not entirely sure that is the particular issue here though, it's unfortunately quite difficult to figure these things out.
So anyway for the time being you would need to use some alternate series of steps to get what you need here.
5632.14 In reply to 5632.13
Thanx Michael
Moved and rotated in Right cplane, and scaled by 30.
Extruded in -Z direction.
Inset only works in a narrow range around value of 1.
Size: 92.6 KB, Downloaded: 48 times, Dimensions: 349x324px
5632.16 In reply to 5632.15
what do you mean "Moved and rotated in Right cplane" ?
5632.17 In reply to 5632.16
Oops, should have said "moved and rotated the two most low and most wide points to the origin and X axis." (This is not really necessary, I just
like things to "line-up.")
Show messages: All  1-9  10-17
