Squircle script
 1  2-21  22-41  42-44
5616.42 In reply to 5616.40
Hi James,
With your 5 by 5 grid:
In the info window for squircle_FG, both radius of 1, and radval of 10 are showing up.
Maybe radval should be changed to radius, throughout the node???
5616.43 In reply to 5616.42
Brian,
Yes that would be better.
quote:
For me, version control is challenging. I have 8 versions in my curves2 menu in the nodeeditor.
My "curves" menu has so many deprecated nodes that it runs off the bottom of the screen, so I had not seen "squirrel_FG"
Thanks for your help
5616.44 In reply to 5616.43
Thank you James.
Latest version of squircle_FG.js:
The only change is that the variable radval is now changed to input variable radius, throughout the node.
This was done because radval was showing up in the Info panel, in addition to radius.
(radval = radius, so radval is not needed.)
I did not change the name, so suggest replacing old squircle_FG with this newly modified one, for the 5 people who recently downloaded the former version.
Show messages:  1  2-21  22-41  42-44
