Squircle script
 1-16  17-36  37-44
5616.37 In reply to 5616.36
Great Work Brian,
It works perfectly now!
The only thing I would say is that a sqfactor range (0,1) might be more intuitive than the present minimum of 0.001
below which the curve disappears. This may simply be a line of code equating any variable value < 0.001 with 0.001
Anyway that's a small thing. The node works brilliantly as is.
5616.38 In reply to 5616.37
Thank you James.
Managed to get rid of the vanishing squircle for sqfactor = 0.
Was not able to reproduce your .nod. Some of my settings must be incorrect.
(Updated version of squircle_FG is in post 44.)
EDITED: 20 Feb 2022 by BEMFARMER
Message 5616.39 deleted 20 Feb 2022 by JFH
5616.40 In reply to 5616.38
Thanks Brian,
I don't know if this is only happening for me, but "centre" input remaining in the code
it has disappeared from the node.
Any thoughts?
5616.41 In reply to 5616.40
Hi James,
The "final" version has an underscore before the FG. Namely: Squircle_FG.
"final" in double quotes, meaning the latest so far.
For me, version control is challenging.
I have 8 versions in my curves2 menu in the nodeeditor.
Also, I believe that loading a previously saved node program often loads an old version of the (node).js,
which needs to have the squircleXXX(old) version removed from the node program, and the
squircleXXX(new) version wired back in. (And newest node program re-saved...)
Ocasionally, sometimes it seems like notepad++ does weird things, or I made a mistake...
Also if the newer squircle version does not have the proper matching squircle name updated here:
LiteGraph.registerNodeType("Curves2/squircle_FG", squircle_FG);
then the node shows up in the curves2 menu as an older name...
I did get your 5 by 5 squircle grid, but my settings for reRange and/or upstream was not set properly (I guess.)
5616.42 In reply to 5616.40
Hi James,
With your 5 by 5 grid:
In the info window for squircle_FG, both radius of 1, and radval of 10 are showing up.
Maybe radval should be changed to radius, throughout the node???
5616.43 In reply to 5616.42
Brian,
Yes that would be better.
quote:
For me, version control is challenging. I have 8 versions in my curves2 menu in the nodeeditor.
My "curves" menu has so many deprecated nodes that it runs off the bottom of the screen, so I had not seen "squirrel_FG"
Thanks for your help
5616.44 In reply to 5616.43
Thank you James.
Latest version of squircle_FG.js:
The only change is that the variable radval is now changed to input variable radius, throughout the node.
This was done because radval was showing up in the Info panel, in addition to radius.
(radval = radius, so radval is not needed.)
I did not change the name, so suggest replacing old squircle_FG with this newly modified one, for the 5 people who recently downloaded the former version.
Show messages:  1-16  17-36  37-44
