how to bend this wormthread?
All  1-4  5-12
I was thinking to do a loft or sweep, between two copies of the gear profile. Rotate one of them first,
to sort of match the helicalness...
Boston gear has a free book called "Gearology." Download at their site did not work, but it can be downloaded here:
http://www.beknowledge.com/archives/article/gearology-handbook-on-gears-for-mechanical-engineering
MITCalc has a free 30 day trial.
Lots of math...
5612.6 In reply to 5612.5
Yeah if you do a google image search just for "worm gear", a lot of the images that show up do show the flat gear to have some kind of twist to it. That could be done by Loft like you mention, or also by applying a Twist deformation onto an extrusion.
But I think that you won't want to be trying to bend a second worm thread to make that piece.
Probably if the main worm thread is a bit thicker at its tips it would require some more rotational allowance in the other gear, if it's thin enough maybe a totally flat one will work ok I guess.
5612.7
A wormwheel tooth form is generated from a hob with trapezoidal shaped teeth, which I don't think would be reproduced by simply bending the worm into a circular shape.
See this video of how they are actually made http://pounceatron.dreamhosters.com/shop/hob/hobbing-gear.mp4
I can't think how you would faithfully recreate this in MoI or any other CAD come to that without quite a bit of work.
Martin (2).
EDITED: 27 Dec 2012 by BLOWLAMP
5612.8 In reply to 5612.7
Here is a way to make a simple helical gear in Catia, starting from a spur gear. Just add the rotation angle psi, to match the worm.
Should be easy to do, in MoI. It is not "single enveloping worm gearing," as the gear does not wrap around an arc of the worm in a semi-circular arc curve.
http://gtrebaol.free.fr/doc/catia/helical_gear.html
The site links to how to make a worm, and how to make a spur gear.
It explains the relatively simple math.
For "double enveloping worm gearing," the worm wraps around an arc of the gear, as well. It is much more mathematically complicated.
An example is the "cone drive."
The mp4 does not play for me, with Real Player. VLC did play it. The avi file worked in Real Player.
EDITED: 27 Dec 2012 by BEMFARMER
5612.9
Ok thanks guys.
I made it..
I used the Gear-Script. It was the simplest way to do it, and it works!!! :-)
Layerheigh 0.15mm
EDITED: 13 Feb by BLACKBIRD
5612.10
Here's a gear I made from an old DXF file I had on my computer.
I extruded the outline and then used the Twist tool to make the gear into a helical tooth form and this should be the same as the helix angle of the worm so as to allow the axes of the worm and wheel to be perpendicular to one another.
Martin (2).
5612.11 In reply to 5612.9
Hi BlackBird, that's cool that it's working!
Did Flow for the arbitrary enveloping radius, then did the twist.
Finally got it to be a solid.
EDITED: 9 Aug 2013 by BEMFARMER
Show messages: All  1-4  5-12
