How make that ?
 1-13  14-33  34-53  54-73  74-75
5590.34 In reply to 5590.33
I didnt have another ACIS based system to look with, but here's a quick look at ParaSolids Handeling of the file. (Autodesk failed to load the SAT file)
Note how converting the surface to NURBS actually has Parasolids reconstruct the trim boundries completely different.
It's a good view to see how different kernels will do things differently. Interoperability has always been a burden. All the understanding will go along way in helping people get results. Parasolids will do the same thing to other kernels. The higher end fancy stuff doesnt go around "generic" or you wouldnt need higher end fancy stuff.
It's a good lesson for anyone who would "blame" a software. ACIS isnt really doing anything "BAD". If you keep the analytic surface analytic surface, then it's perfect!
5590.35 In reply to 5590.34
Hi Burr, can you try importing the version attached here without any fillet into Parasolids, then do a fillet with a setback to generate a new fillet there and then export that back to STEP and post it here? It would be interesting to be able to compare the Parasolid generated n-sided patch at the juncture area.
5590.36 In reply to 5590.33
Hi Martin,
> In one way I was hoping you were going to say that it was poor integration of ACIS into
> ViaCAD, because that can be worked around.
Well I can't say for certain that is not the case since it's not like I have any specific information on the internals of ViaCAD.
But it seems doubtful that it would be a problem specific to only ViaCAD rather than ACIS itself.
> As a last grasp at this Michael, do you (or anyone else, reading this) have some other ACIS based software
> that you could try importing the SAT file contained in my zip attachment, and check whether/how the
> problems persist there?
I gave it a quick try with Alibre, and it's hard to see for certain but it appeared to open with the lumpy surface in place from the start, which probably means that Alibre converts these kinds of analytic surfaces into plain NURBS , either that or it uses the NURBS version of the surface for its display.
5590.37 In reply to 5590.35
FYI here's a couple from NX the 'NX_default_fillet.3dm' is using the default filleter with setback in NX, to get an n-sided surface that's a seperate feature shown in 'NX_n_patch.3dm'.
5590.38 In reply to 5590.37
Thanks Danny. I couldnt provide the result because i use a version which requires me to pay to export out a model. I was going to ask you anyway :o
I didnt do the fillet (lack of understanding). The autodesk filleter made the star fillet method the same as the nx file Danny Posted.
Here's a video of doing the original patch to show some of the results (Not the same as reviewing the file, but an idea of how they are doing it)
It looks to be somewhat the same as Rhino's. The other thing to note is doing the patch ion the extended part to get a smooth surface. (Kindof one of your mantras Michael).
Anyway, Cant provide the file, but maybe some others with solidworks or something could present something.
5590.39 In reply to 5590.37
Hi Danny, thanks for posting the NX examples!
That's interesting that the default filleter uses the star method. That result does have some of those little star-pattern bumps in it.
The N-sided patch result looks really nice! No little wiggles or bumps in there.
5590.40 In reply to 5590.39
> ...The N-sided patch result looks really nice! No little wiggles or bumps in there.
> - Michael
Hi to all.
Yes it does look nice, and with a rather ironic twist, because if I export Danny's file from MoI as a SAT file and then import into ViaCAD (ViaCAD Pro actually, which is where the surface analysis shots come from), it comes in pretty well (GRRR)!
It's a pity ViaCAD can't export its own files with similar accuracy (GRRRRR)!
I'll think about taking the issue to the ViaCAD forum as it's not really a MoI problem, but I must say that this is a nice place to chat about these things - I always feel I've learned something here, so thanks to everyone for helping out :)
Cheers.
Martin (2).
EDITED: 10 Dec 2012 by BLOWLAMP
Size: 732 KB, Downloaded: 83 times, Dimensions: 1176x834px
Size: 2.1 MB, Downloaded: 62 times, Dimensions: 1344x834px
So now what is the best way for simulate the best result in Moi ? 6 stars ?
5590.42 In reply to 5590.38
Hi Burr,
No Problem, I was familiar with Powershape, I used it at the previous job I had, but then Powershape was using the ACIS kernel, now they're using the Parasolid kernel which I believe they changed to in the past few years. Is that Powershape-e you're using? I read somewhere they brought out a 'pay as you export/translate' software model, pretty cool if you want to learn the software without the outlay and risking trying to download a pirate copy, I think the other vendors like Solidworks and Seimens NX should release something along that model.
5590.43 In reply to 5590.39
Yeah, the thing I like about NX's n-sided surface it has a lot of control options to achieve the desired result, not that I use it much in my line of work but hey it's good to know it's there.
5590.44
The Solidworks version is almost identical to the NX version except I noticed the SW version has a looser control point structure, It's possible to tweak the patch further in both software's.
5590.45 In reply to 5590.42
Hey Danny,
"""""""""". Is that Powershape-e you're using? """"""""""
Yes... It's very cool to have access to the software. At least they lowered the price for exchange (The cost of using the translator per model). It's something like $79 now.
""""""""""but then Powershape was using the ACIS kernel, now they're using the Parasolid kernel """"""
I think they had a proprietary kindof version (Heavily modified) ACIS. They actually still have BOTH! You can convert between them. You can see me do it in the video. They call it "power surfaces" or something like that... Side note, they even use MESH.
""""""the thing I like about NX's n-sided surface it has a lot of control options to achieve the desired result""""""""
I think thats whats getting the result. But maybe alot of "how to use those" will go along way ;-)
5590.46 In reply to 5590.41
The best way is to not do it in MoI - isntead do this particular shape in one of those other CAD programs and then bring the result into MoI.
That will probably be the best way to do it until MoI gets its own n-sided blend tool.
5590.47 In reply to 5590.44
Hi Danny,
So in both these cases for NX and SolidWorks, did you have to manually delete the "default fillet" star-structured corner and then construct the n-sided patch as a separate step? Is there no way for the initial filleting to make n-sided corner patches from the start?
Although the SolidWorks generated n-sided patch is not lumpy, it also looks to be significantly not G1 at its connection to the boundary surfaces, I think it's actually too light and maybe needs to have parameters fiddled with to give it more control points to work with in order to hug the boundary's normals better.
5590.48 In reply to 5590.46
Cool! For the V3 ?
So wait and see and take some rucksacks against suitcases for travel around the world :)
5590.49 In reply to 5590.48
> Cool! For the V3 ?
I hope so!
5590.50 In reply to 5590.47
So, if a fairer patch could be made by the library guys (like unto) SW's version, which seems to sacrifice edge accuracy for lumpiness, could there be a way to 'brute-force' G1 to the seams, or some kind of 'adequate' matching? Which will no doubt add new lumpiness...
Okay, I know that the N-sided patch is revealing itself to be a tall and perhaps implausible task, but does the 'star' or 'single skin' method look reasonably better at only three or four sides compared to six? I certainly run into three and four sided spaces more that I'd like, and even the 'star' solution would work better than some of the hackneyed 1-to-1 blend schemes I have to come up with. :-/
Yep, Pilou, these 'other' apps are wayyyy out of my price range, so it's not a solution I can use.
5590.51 In reply to 5590.50
@Mike
Someone speak to me for another one! ;) Any idea of the price ! But surely not cheap :)
KeyCreator(old CADKEY)
http://www.kubotekusa.com/products/keycreator.html
EDITED: 10 Dec 2012 by PILOU
5590.52 In reply to 5590.50
Hi Mike,
Well, it will tend to have only 3 or 4 lumps in it rather than 6 lumps in it... I'm not sure if that qualifies for "reasonably better" or not though.
It's fairly difficult to talk about such things in the abstract as the devil is in the details - certainly something that is almost planar already and very regularly shaped will be easier to fill in with any method. Do you have a particular three or four side hole that you would like to test with?
5590.53 In reply to 5590.47
Yep, I had to delete the star-structure the default filleter doesn't handle n-sided patch that's a seperate feature, NX call it 'n-sided surface' and SW call it a 'boundry surface'
I'm not a Solidworks expert, I did use a mates seat of the software so I'm not sure how much further it can go, if you like I could have another look.
Show messages:  1-13  14-33  34-53  54-73  74-75
