Flow Issue
5584.1
A Flow issue again.
3 objects, a solid, a base surface and... a target joined(!) surface.
Flow command -> selecting solid -> selecting base surface, ok so far.
But -> selecting target surface returns just a part and not the whole.
How to select the target point of the _whole_ joined surface ?
Any hint ?
Thanks in advance.
Oliver
o5m6.de
Beware of the hun coming out of the sun ;-)
Size: 34 KB, Downloaded: 92 times, Dimensions: 643x519px
Size: 35.8 KB, Downloaded: 75 times, Dimensions: 643x519px
Size: 40.1 KB, Downloaded: 125 times, Dimensions: 643x568px
5584.2 In reply to 5584.1
Hi Oliver, Flow works from one base surface to one target surface - when I say surface I mean just one surface, a "joined surface" is many surfaces joined together and the target can only be just one of those surfaces not the whole thing except for when you use "projective" mode for the Flow.
So in order to get what you want you will need to reconstruct the target object to be just one surface rather than a set of 3 separate joined together surfaces. To do that you will need to remove segmentation in any input curves you are using to construct the surface - if you do an extrude or sweep or something with a curve that is made up of multiple joined together segments, then the result will be multiple joined together surfaces as well.
So if you have a segmented curve you need to combine the segments together before using it to create the target surface. You could draw a new curve using Draw curve > Freeform > Control points that was just one long curve to do that, or also the Rebuild command can be useful for removing segmentation as well:
http://moi3d.com/2.0/docs/moi_command_reference10.htm#rebuild
5584.3 In reply to 5584.2
Very comprehensive, as usual.
Thanks a lot, Michael !
Oliver
o5m6.de
