Text
All  1-2  3-6
5562.3 In reply to 5562.2
Hi Mickael, ok I understand .
It s when I work on some cosmetic POP with silkscreen needed.
I prefere to modele the text better than open photoshop and create map to be used in my rendering software.
It's more flexible to determinate and play with the position. Anyway, thanks for your fast reply.
Alex
5562.4
Hi Alex,
You can import with Moi3D -> "2D vector files" -> *. eps, *. ai and *.pdf.
With AI, Corel, Inksacpe, ...you can create your "Text-Vector" file -> Import with Moi3D -> Extrude...
http://www.brandsoftheworld.com/ ;-)
5562.5 In reply to 5562.4
Hi Ralf ,
yes I know I can import but I wanted to reduce the number of soft used, and do the maximum in MOI without have to switch of software;).
Alex
5562.6 In reply to 5562.5
Hi Alex, yes in the future I want to add more 2D type functionality to MoI which will make it easier when you're using it more for generating 2D drawing only rather than really 3D modeling. A lot of things like the Text tool are quite a bit more oriented towards 3D modeling use currently.
Until the time that some more 2D tools like that are added into MoI directly you would probably be best off doing the import method for now.
Show messages: All  1-2  3-6
