Text
All  1  2-6
5562.2 In reply to 5562.1
Hi Alex, text as a 3D NURBS solid is much more heavyweight in data complexity than text in a word processing document, so it's not really a great fit to optimize the text tool for high amounts of text entry since that can quickly become too complex of a 3D model.
That's why the text tool in MoI is focused on just entering in a single line of text that might be used as a raised label as part of the model or something like that.
What kind of model are you creating where you're needing to enter in paragraphs of text as part of the model? In general it's pretty uncommon for manufactured objects to have that quantity of text embedded into their shapes...
I think that at some point in the future there will be a different kind of text tool - one that will add in "annotation text" for 2D labeling, and that will likely include some things like alignment and multi-line entry. Right now I'm not sure exactly when that will happen.
5562.3 In reply to 5562.2
Hi Mickael, ok I understand .
It s when I work on some cosmetic POP with silkscreen needed.
I prefere to modele the text better than open photoshop and create map to be used in my rendering software.
It's more flexible to determinate and play with the position. Anyway, thanks for your fast reply.
Alex
5562.4
Hi Alex,
You can import with Moi3D -> "2D vector files" -> *. eps, *. ai and *.pdf.
With AI, Corel, Inksacpe, ...you can create your "Text-Vector" file -> Import with Moi3D -> Extrude...
http://www.brandsoftheworld.com/ ;-)
5562.5 In reply to 5562.4
Hi Ralf ,
yes I know I can import but I wanted to reduce the number of soft used, and do the maximum in MOI without have to switch of software;).
Alex
5562.6 In reply to 5562.5
Hi Alex, yes in the future I want to add more 2D type functionality to MoI which will make it easier when you're using it more for generating 2D drawing only rather than really 3D modeling. A lot of things like the Text tool are quite a bit more oriented towards 3D modeling use currently.
Until the time that some more 2D tools like that are added into MoI directly you would probably be best off doing the import method for now.
Show messages: All  1  2-6
