UVW issue from MOI > C4D
All  1  2-6
5557.2 In reply to 5557.1
Here are screen grabs out of C4D, showing the difference in the material mapping...
Size: 341.4 KB, Downloaded: 64 times, Dimensions: 1578x943px
Size: 267.7 KB, Downloaded: 61 times, Dimensions: 1578x943px
5557.3 In reply to 5557.1
Hi sneather, the UV mapping that MoI exports is very rudimentary and will usually need to be replaced by a proper one inside of your poly modeling program.
The default one that MoI generates has every surface covering the entire texture rectangle rather than every surface having its own little separate island area.
In the future I want to make an "island generator" mechanism that will generate a better default UV map, but usually every poly modeling program has their own functions for generating a UV mapping by an unwrapping process, that's what you will need to apply on to your exported model in order to get a properly usable UV mapping set up on it.
5557.4 In reply to 5557.3
Okay. Thanks. I hope you do, indeed, implement such a feature. But at least I know that there is no solution to chase down in MOI.
5557.5 In reply to 5557.1
Hi sneather, also if for some reason Cinema4D's own built in UV mapping generators are not suitable for what you're trying to do there are also some stand alone uv mapping tools you can find links to here: http://moi3d.com/forum/index.php?webtag=MOI&msg=5119.9
But basically when it comes to uv mapping MoI does not attempt to make a particular useful version of that itself, you'll need to use some polygon modeling tool to get that part set up.
5557.6 In reply to 5557.5
Thanks. UVW mapping isn't one of my strong suites, unfortunately. But I'll probably need to improve that component of my workflow, one way or another.
Show messages: All  1  2-6
