Hi all,
Some news to let you know what about my aim doing "unfold" for a "sail-like-kite" fabric shape.
First I would like to thank you for your ideas, because for instance the information about the Rhino "squish" command will help me a lot : I will design my "sail-like-kite" shape within MoI then I will send only the native 3dm MoI file to my sailmaker and he will be able to "squish" it within his Rhino3D to flatten my shape and obtain the plan he needs to cut sail fabrics. Good friends folks, you save me a lot of time and problems !
Second maybe all this will not be needed as David Aberdeen - the SurfPlan developper - explained to me why SurfPlan shape I have done did not work well (my fault) and he kindly proposed to send me the DXF files to let me work on this, so I will do my task this time within SurfPlan because its aerodynamic settings will help me a lot...
Third all this walk will help me a lot for my future projects : I definitely learned a lot with your help :-)
At last, I have found a pretty good solution to unfold 3d objects just with MoI and light softwares :
1) do your shape within MoI
2) save your file in SketchUp skp file format, fine tuning the meshes
3) within SketchUp you can use the UnfoldTool plugin ( http://sketchuptips.blogspot.fr/2007/08/plugin-unfoldrb.html) or maybe better the Flattery one ( http://www.pumpkinpirate.info/flattery/)
4) export DXF with a free DXF plugin ( http://rhin.crai.archi.fr/rld/plugin_details.php?id=774) or directly in SWG within the Flattery toolbar
Hoping this will help some folks,
Guy
