Circle through two points & tangent to an arc.
All  1-8  9-17
5513.9 In reply to 5513.8
So simple and works with any 2 points, circles...
And when you have drawn your circle 3 Points as I said just rotate as inverse :)
EDITED: 30 Oct 2012 by PILOU
5513.10 In reply to 5513.9
Hi Pilou, again you seem to be assuming that always the 2 points are equally spaced from one another.
Here I will exaggerate it a bit more, try with this example and with the attached file:
It is indeed simple if the 2 points are exactly balanced and form an isosceles triangle with the center of the circle as you keep showing, but that's just one special arrangement of points.
5513.11 In reply to 5513.10
This special case asks some reflexion! :)
5513.12 In reply to 5513.11
Hi Pilou, the one that you are showing the solution for is the special case with points arranged in a particular configuration. I don't believe that your solution works for the more general case where the points are placed anywhere...
5513.13
Well here's my solution http://screencast.com/t/EngogKiRXu6C
I don't know if it's the same as the way shown in bemfarmer's link, as that was hard for me to follow, but somehow I got to work it out OK.
Martin (2)
5513.14 In reply to 5513.13
Hi Martin, I'm glad that you got it solved. I will look into adding this case into the circle and arc tangent commands.
So for your special case :) (I have made a general rotation for more practical explanation ;)
Cool movie solution of the mirror trick !
5513.16 In reply to 5513.14
>>- Michael
Michael.
That would be nice if you can do it and definitly appreciated by me - not because I perform this particular manoeuvre on a daily basis, but it would be one less interruption to hamper workflow when the need arises.
Well apart from this one case, I must say that I tried quite a few different tangent intersection scenarios and have come away very impressed with the logic built in to MoI and its ability to find the right solution. Most software seems to either give a null result or insist on jumping to the wrong side of the arc when doing one of the more unusual kinds of blend.
Thanks to all for helping.
Martin (2).
5513.17 In reply to 5513.16
Martin(2), your mirror by midpoint method, with construction line and circle tangent command is very nice.
In your example, there are two circle solutions. There are other cases...
I've never studied inversion/reflection in a circle, nor radical axis, and haven't grasped it yet. Here are a couple of pdf's on the subject:
http://geometer.org/mathcircles/inversion.pdf
http://jwilson.coe.uga.edu/MATH7200/InversionCompanion/inversion/inversionSupplement.pdf
So what would a MoI command to invert some geometry, with some circle do?
Show messages: All  1-8  9-17
