Shell and network surface
All  1-4  5-8
551.5
Thank you Michael.
***There is always a better way to do things... Just find your Moment of Inspiration***
551.6 In reply to 551.4
These curves produce a smooth single surface in Rhino as a network surface.
They do work in MoI with a 2 rail sweep and a scale rail as a polysurface, but there are some creases.
Are there a certain number of curves that work in MoI's
network surface or a particular orientation of curves that is more conducive to smooth surfaces?
Rhino has that option to sort curves by direction when they are going every which way..
I can't usually get it to work, but at least I know the direction is the problem, then. ;-)
Jesse
EDITED: 22 Apr 2007 by JESSE
551.7 In reply to 551.6
Hi Jesse - your "central rail" there is not entirely smooth - it comes to a sharp point where it starts the upward bulge. Generally those types of sharp points are not going to work well in a scaling rail.
Your network layout is very clear there, MoI is not getting confused about the directions, instead it is having a hard time combining the multiple curves together into one single surface, the resulting surface is getting too dense. I should be able to do some work that will help to solve this and also for other areas that combine multiple curves together into a single surface such as loft and sweep.
I thought a bit about putting in some sort of "manual direction" picking like Rhino has an option for, but I haven't yet seen the type of network that would need it. I'll add it later if something like that shows up, but I think that anything that can't be sorted automatically probably won't be a valid grid network for this command anyway.
I tried your curves in Rhino, and got a nice smooth surface result, but it is also a bit strange in a couple of aspects, it seems to ignore the sharp corner in your central section, and seems to sag away from some spots nearby that by more than the allowed tolerance:
Do you think it is better for creases in your input curves to be ignored like this and sort of automatically smoothed out?
I kind of would expect for there to be a crease in the resulting surface corresponding to the crease in your input curve...
551.8 In reply to 551.7
This was originally a Rhino model. I put the sharp angle
in there to replicate a jade ring that someone wanted
redesigned for a faceted stone, but I agree that it's not
consistent with the rest of the design.
My curves from last year weren't smooth...I just drew them over
in MoI using blends and G3 fillets...the sweep turned out a lot better, perfectly
actually. :-)
The option to smooth creases in surfaces might be good.
I know you want to keep the "tinkering" aspects of modeling behind the scenes in MoI,
but the ability to rebuild with a certain number of control points is useful when the default sweep settings aren't producing the desired result.
Jesse
Show messages: All  1-4  5-8
