Bit of a problem with Inset.
 1-2  3-22  23-29
5508.3 In reply to 5508.2
I cant tell you why the inset fails, but if you just extrude the outer profile and inset that, then run boolean diff with the 2 inner holes, you can have success.
5508.4 In reply to 5508.1
Hi Martin, so that one is simple enough that I'd expect for it to work, but you're running into some kind of a bug. I may have a shot at fixing this one since it doesn't involve extension problems.
Doing a shell seems to be ok, so another workaround for the moment is to do a shell instead and then extrude up the bottom face of the shell and boolean union that extrusion with the shelled part.
Quick note - whenever you want to push the "Done" button you can use a shortcut of just right-clicking inside of the viewport instead of moving your mouse over to the actual button.
5508.5 In reply to 5508.1
And when you get something that looks weird like that with surface pieces kind of "leaking" out into hole areas or past outer boundaries, it means that the geometry has some kind of mangled trim boundaries, either some edges of the boundary missing, or mangled in some way like with pieces crossing over each other or things like that.
In this case it's some bug in inset or in something that inset uses that is making the mangled result. I'll put it on my list to see if it's possible for me to fix it up or at least figure out which area the bug is at.
5508.6 In reply to 5508.1
Minimum thickness needed is about 2.275, before the inset fails.
I do not know why.
Scaling by a factor of 2, results in a minimum of 2X 2.275 = 4.550 mm.
5508.8
Thanks for checking this out - I'm glad to have brought this to your attention and relieved I was doing things properly.
After playing around with it for a while, I can see that Inset is nice to have in the MoI toolbox, I can see me using it quite a lot.
Is there any reason that a zero value entered into the 'Thickness' property couldn't be made to work - I'm thinking that it might be a way of offsetting an entire surface by the amount entered into the 'Use separate height' property?
Martin.
5508.9
It probably isn't important, but this is just to let you know that the conrod.3dm test file I supplied seems to work OK in MoI v2.
Martin.
EDITED: 27 Oct 2012 by BLOWLAMP
5508.10 In reply to 5508.8
Hi Martin,
If I understand you properly, you can instead use the Construct > Offset command to generate that kind of full surface offset.
> test file I supplied seems to works OK in MoI v2.
Ah, thanks for testing in v2 as well - I have taken some updates to the geometry library in v3 and there seems to be some change that has broken a couple of things that used to work before, I am going to be trying to track that down to fix it. I think it has something to do with calculating intersections involving cylinders.
5508.11 In reply to 5508.10
Hi Martin,
"If I understand you properly, you can instead use the Construct > Offset command to generate that kind of full surface offset."
Hi Michael.
What I had in mind was that it could be used to alter the thickness or width etc of the part and keep it as a solid, rather than offset a separate surface from that solid - I suppose it would be the equivalent of an 'offset face' operation in other software.
Martin.
5508.12 In reply to 5508.11
Hi Martin, I see - but that seems like it could be odd to use Inset for such a purpose since the overall purpose and UI for Inset is focused on making something with a border around it.
Maybe the kind of thing that you're talking about would be better as a separate command or some kind of other option in Offset or Shell instead...
You can get the basics of it right now by using Edit > Separate on the face, then doing a shell, then deleting the bottom face of the shell and then joining it back in.
5508.13 In reply to 5508.12
This notion came about as a natural progression from playing around with Inset.
Whilst trying to find the cause of my problem, I just kept reducing the Thickness setting until I reached the point where zero was the only place left to go :-)
Offsetting the face of a solid to allow it to shrink or grow feels like it could be worth having somewhere in MoI - it'd be great ( for me) for tweaking hole and slot sizes, for instance.
Sorry Michael, but I couldn't follow this bit:- "You can get the basics of it right now by using Edit > Separate on the face, then doing a shell, then deleting the bottom face of the shell and then joining it back in." I'm probably having a blonde moment though, but thoroughly enjoying using MoI.
Martin (2).
5508.14 In reply to 5508.13
Hi Martin,
> enjoying using MoI.
Those are just the steps you can do currently to get the same result as what I think you're looking for with the "zero width" inset.
Step 1 - select the face of the solid that you wanted to do the inset on.
Step 2 - run Edit > Separate to break that face off from the main object and make it into its own separate individual surface. This is because the Shell command in the next step operates differently depending on whether you have an unjoined individual surface selected or whether you have a face selected that is joined to other things.
Step 3 - Run Construct > Offset > Shell on the separated surface. When run on a surface shell thickens a surface into a slab.
So now at this point you basically have all the pieces that you were looking for, the only problem is that the shelled surface is a solid with top and bottom caps, so in order to finish it up you will want to delete the bottom face of this solid slab piece and then with the bottom open you can join the main body and the thickened slab piece together again.
In order to get at the bottom face of the slab you will probably want to hide the main piece temporarily. One quick way to do that is by using the "isolate" functionality - select the slab and right-click on the Hide button. Doing a right-click does an "Isolate" operation which keeps the selected object and instead hides everything else. Then when you're done working on that object, do second right-click on the Hide button and it will restore object visibility to the previous state before you did the initial Isolate.
Hope this helps, let me know if it's still not clear.
5508.15
Hi Michael.
After following your mini tutorial, it's all clear now.
I like the 'isolate' feature for keeping the work flowing smoothly.
Thanks for your help.
Martin. (2)
5508.16 In reply to 5508.1
Hi Martin, so after a whole bunch of testing and debugging I was finally able to track down the bug that was making your original 1mm inset here fail, it was a bug in the latest update to the geometry library.
So I've got that fixed now so the next v3 beta will be able to do that inset again ok.
Thanks for posting the file!
5508.17
Brilliant!
You seem to work very hard on making MoI as good as it can possibly be, so thanks very much for that.
Martin (2).
5508.18
Michael.
I'm using the November 2012 release here.
If you extrude the conrod.3dm to (say) 20mm and do an Inset on the top face with the Thickness at 2mm, Direction = inwards, and the other two options unchecked, then no inset happens (for me).
Swapping the Direction setting or ticking the Use separate height feature seems to clear the problem - even if these options are then subsequently reverted.
Just to mention that when I tried Inset for the very first time on this beta, I saw a surface leak through the large hole of the conrod file, but I haven't seen that happen since.
Thanks for all your hard work.
Martin (2).
EDITED: 6 Nov 2012 by BLOWLAMP
5508.19 In reply to 5508.18
That's a strange one Martin, it's quite random, sometimes it works sometimes it doesn't. I did find if inset fails, hit cancel, leave top face selected, hit inset again and it works.
Something for Michael to investigate.
5508.20 In reply to 5508.19
Yes, it is Danny, but I have a supernatural ability to find these things you know :-)
Martin (2)
5508.21 In reply to 5508.20
:) I don't know if having a supernatural ability in finding problems is a good thing or bad thing ;)
5508.22 In reply to 5508.21
Errr... I'll ask the Mrs when she gets home ;-)
Martin (2).
Show messages:  1-2  3-22  23-29
