Bit of a problem with Inset.
 1-4  5-24  25-29
5508.25 In reply to 5508.24
Hi Martin, I'm able to reproduce the occasional inconsistent behavior, so there's definitely still some other bug lurking around in there somewhere, sometimes this kind of sporadic failure can be due to bugs using uninitialized memory.
I'll continue to dig into it and see if I can track down this other bug too, it can be hard to get to the bottom of things that don't reproduce reliably though but I'll try.
5508.26 In reply to 5508.24
And hey, at least it works some of the time now, that's some amount of progress since in the last beta it was broken all the time... ;)
5508.27 In reply to 5508.26
Hi Michael...
...I think we all know that you won't be able to rest until you've got to the bottom of it :-)
Martin (2).
5508.28 In reply to 5508.27
Hi Martin, so I think I've finally gotten to the bottom of what was going wrong with the Inset case that you posted in this thread - it had to do with a bug in the "test for coincidence between closed curves" mechanism in the geometry library.
I've got it fixed for the next v3 beta and it looks like this case that was behaving with sporadic errors should work properly after that.
Thanks for posting the example file.
5508.29 In reply to 5508.28
Nice one, Michael!
Thank you very much - I hope it didn't take too much time to find + fix.
Cheers.
Martin (2).
Show messages:  1-4  5-24  25-29
