F 16 wip
 1-5  6-21
5504.6
Still working... ;)
5504.7 In reply to 5504.6
Looking good Kagan, your doing some excellent looking work there, just be careful with the amount of detail you add otherwise exporting can become difficult, unless of course you break it down into smaller chunks and work on them, otherwise keep it going it's really sharp!
Martin
5504.8 In reply to 5504.7
> just be careful with the amount of detail you add otherwise exporting can become difficult, unless of course you break it down into smaller chunks and work on them...
Yes.
If you apply a name to each component type - like "push buttons". You can show or hide them, which if temporarily hidden, will speed up your modeling work flow.
And when you export your .obj's to render, all you have to do is turn off everything but what you want to concentrate on, and you'll save simple and logical chunks to work with in your rendering program. Plus, you'll be able to vary the amount of tessellation (poly) detail on each component.
5504.9 In reply to 5504.7
Thanx Martin. I'm testing the app. Looking good now and very very stable. There is no crash. I'm exporting the mesh in small pieces and in fbx format. Looking good. As I expected. I'm using Ati card. 4650 an older card. But everything is fine. (Money problems ;) )
5504.10 In reply to 5504.8
Thanx guys for your interests. ;)
5504.11
İmported as Fbx... No problem at all. ;)
5504.12
Nice!!
Martin Spencer-Ford
5504.13 In reply to 5504.11
nice
5504.14
5504.15 In reply to 5504.14
Wow that's some fantastic detail on the interior!
5504.16
Still working ;)
5504.17 In reply to 5504.16
Still looking good too!! - Keep going.
Martin Spencer-Ford
5504.18
Phenomenal undertaking Kagan! It's looking more impressive with time.
5504.19
very nice work on working all the details.
I was looking at a F16 blueprint that have the section cuts, did you happen to use those sections to start modeling?
5504.20
Trial ended sorry :(
5504.21 In reply to 5504.19
First I collected many photos (thanx to google)
And many blueprints as well. it is very hard to model an f 16. the sections front body and cockpit all challenging. I can do only these parts in 30days trial time :( .and its ended.
Show messages:  1-5  6-21
