Little bug?
5500.1
right now i've discovered this weird thing:
in a blank file start to use text tool font=ARIAL :take a look at the inner triangle of the letter -A-,it's bended
see left point out of simmetry:it's a bug or something else?
5500.2 In reply to 5500.1
Hi, that seems to be a feature not a bug. See the attached screenshot. I also never noticed that before but thats the way this font is designed.
A font without that bulge would be Helvetica.
EDITED: 24 Oct 2012 by MARTIN3D
Size: 65.1 KB, Downloaded: 49 times, Dimensions: 1092x804px
5500.3 In reply to 5500.1
Hello,
thats not a bug, its a feature:-)
Moi displays the curve correct. Fonts are normaly very small... and for better reading and a cleaner view they got this little curve.
There is a word for this... but i don´t remember:-)
best regards
tijai
5500.4 In reply to 5500.3
funny... two nearly same answers...
and i´m to late..
5500.5
..never seen this little detail...just a strong close up can show the little bendy triangle...thanks guys !!
M
5500.6 In reply to 5500.5
A lot of times fonts have things that are slightly odd when they're used for 3D object geometry rather than for small sized 2D print like they were originally designed for.
I'd never noticed that little bend on the Arial A before myself either, but it's definitely part of the font - I also tested making a big A in MS Word and you can see it there too.
5500.7 In reply to 5500.6
I use Arial quite a bit with MoI, seen the bump, but just assumed MoI would not make such a mistake so it had to be the font it's self :)
