Hi oli, thanks for sending the file - over here your embedded images show up fine on Windows, is it possible that you've set tranparency to 100% in the image options ?
> because they are no more displayed in the list, neither in the embeded nor the unembeded file version.
It's normal that only the base file name is displayed in the list and not the full path because there isn't much space in the list.
But if you click on one image in the list to select it, you can then push the "Properties" button here:
That will open up a dialog where you can edit the path. Also you should be able to put the .tif files into the same folder as the 3DM file and then push the "Reload" button on that properties dialog and it should then reload the image at that point.
Are you maybe using an old version of MoI on Windows ? Maybe there is some problem with some specific MoI version, I'm testing with the current v3 beta over here where your embedded image seem to show up ok.
