makeHexRod script
All  1-4  5-12
5489.5 In reply to 5489.4
Hi Mattj,
on a Mac it's a bit harder to get to the commads folder but once you found it just pull this folder to the SideBar of the Finder for quicker access in the future.
I attached a visual guide.
EDITED: 19 Oct 2012 by MARTIN3D
Size: 57 KB, Downloaded: 101 times, Dimensions: 803x803px
5489.6
thanks for help. MOI support brilliant as ever!
I think this would be even better if you could choose specific sizes say DIN.
5489.7 In reply to 5489.6
I actually started this script with hex nuts in mind and it had a drop down list of DIN EN ISO 4032 sizes but then I found this limiting. This script can do more :) Now you have to look up a table but you get a more universal script. You also want bolt heads, higher nuts, imperial sizes or just a plain hex rod.
EDITED: 21 Oct 2012 by PILOU
5489.9 In reply to 5489.8
Mmmmm....
Thanks for the script Martin!
...yes! I can make "stand-offs" too by inputting my desired height. It will be useful for circuit projects planning.
EDITED: 21 Oct 2012 by MAJIKMIKE
5489.10
Martin, thank you very much.
I like this handy script, so I decided to improve it.
Here is the changelist:
Nut and bolt size table (ISO 4032/4014, ASME B 18.2.2)
Chamfer depth setting
Some interface improvements
EDITED: 7 Mar 2022 by SMIRNOV
5489.11 In reply to 5489.10
Excellent!
5489.12 In reply to 5489.10
Cool Max, thanks a lot.
Show messages: All  1-4  5-12
