Dual Monitor Setup
All  1  2-5
5486.2 In reply to 5486.1
Hi Apophis,
> is there a way to place the ui on a second monitor or to work on two different views?
Sorry, no there isn't any way currently to do that. But it is on my "todo" list to work on making an option for putting the whole side pane onto a different monitor.
5486.3 In reply to 5486.2
You can drag the window size so that the side menus are on the second monitor and then use a whole screen for the workspace, I've been working like this and it's great. You can change the side the menus are located in the 'options' and the 'general' tab, works a treat and tbh can't really see why you need too much else as there are so few menus.
Loving this program! just wish i had more time to play with it.
PS - Can anyone post a short cut script to assign a view to a key... ive been using the below on one key but need to amend so I can assign top to the letter t, front to the letter f etc.. but tried amending but cant get to work (sorry for the thread hijack):
script: /* switching over views */ var views = [ "3d", "top", "front", "right"]; var vp = moi.ui.mainWindow.viewpanel; var current = vp.mode; for (var i = 0, len = views.length; i < len; i++) {if (current == views[i]){ vp.mode = views[(i+1)%len]; }}
5486.4 In reply to 5486.3
Hi Cube, check out here for some scripts for setting the view:
http://moi3d.com/forum/index.php?webtag=MOI&msg=3808.2
5486.5
perfect! looked everywhere for that. thanks
Show messages: All  1  2-5
