how to close these holes?
5480.1
I want to know if there is an easy way to close these 2 holes. the bigger one I was able to close by cutting the object in 2, then selecting the edge of the opening and blend it. but that does not work for the circular opening.
and the first solution is also a bit awkward I think.
any better techniques?
tnx
wim
5480.2 In reply to 5480.1
The little circular hole is easy, select the surface, then select the edge, and just delete the edge. Then delete the two half circular pieces. Or vice versa.
How about a loft?
5480.3
Is this what you want ? If so then use loft and then fillet @ 0.25 with a G2 blend
Martin
EDITED: 26 Jun 2015 by TPWUK
Size: 45.5 KB, Downloaded: 215 times, Dimensions: 739x767px
5480.4
how do you use loft with just one curve selected? doesn't do anything here. if I select the lower circle too, I get an open tube, but no volume.
wim
Deleted
EDITED: 16 Oct 2012 by BEMFARMER
5480.6 In reply to 5480.4
Select one of the top edges and copy and paste it.
Go to the right view and grab one of the edit frame handles and "sqeeze" the surve until it says "flat"
Move the curve to the front a bit.
Run seperate on the surface object and delete the bottom planar surface.
Do an Edge selection on the surface and hit Ctrl+A to select all edges and hit delete.
Select the hollow cylinder and run Construct-Planar
Use boolean diff on the cylinder with the extracted edge.
5480.7 In reply to 5480.1
Hi wim, so yeah like bemfarmer mentions above the circular hole can just be deleted by an "untrim" operation (select the open edge and hit delete). Some more information on untrim here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=444.4
For the second kind of hole, the easiest method for that is to make your base object into a solid and then use a 2D side profile curve to cut away the material in the first place. Doing it that way will produce "side walls" automatically and you won't have any hole to fill in at all.
See these posts for some examples and explanations:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5075.3
http://moi3d.com/forum/index.php?webtag=MOI&msg=3883.3
http://moi3d.com/forum/index.php?webtag=MOI&msg=1359.2
http://moi3d.com/forum/index.php?webtag=MOI&msg=1359.6
http://moi3d.com/forum/index.php?webtag=MOI&msg=4344.2
It looks like you may be doing something like using Edit > Trim to cut the surface up by a side profile then leaving that hole - dont' do that, instead make sure your base object is a solid and then use boolean difference to cut it rather than Trim, the booleans are more oriented towards keeping things as solids while trim is a surface modeling operation. Behind the scenes the booleans will do the equivalent of an extrude of your profile curve, trim both the base solid and the extrusion, and automatically keep and join the right pieces to make new solids with "side walls" on them. So it can save a lot of time to use the booleans since it bundles up a fair amount of other low level operations in it, you'll be doing a lot more work if you try to do all those low level operations each individually.
If you did want to do things in the "low level" way to fill that kind of hole you have there you would not want to be working only with the 3D edge curve that's the result of a trim but instead extrude out the original 2D cutting profile so that you have the extruded surface and then also trim that extruded surface to produce the side wall cap part, one of the links above shows that method. But it's far easier to just use a boolean instead and then have no holes at all to deal with filling...
The preceeding two responses are excellent.
Ran through BurrMan's example a couple of times.
5480.9
Thanks Michael, Bemfarmer and Burrman, lots of things learned again today!
