Majik Tutorial: The Turbine-Style Sports Rim
 1-17  18-37  38-46
5470.18 In reply to 5470.17
Thanks Mike for restoring the replies in this thread!
5470.19 In reply to 5470.18
hahaha well you could have delete my "LoL" post :-)
But nice to see the posts back again,
Peace,
Rich_Art. ;-)
5470.20
Hi Ed,
I realized your one render was submitted as a MoI post:
but I keep everyone done of my tutorials! ;-)
5470.21
Here's my attempt at a render:
My focus was on the rim metal which is supposed to be a polished alloy aluminum with a ceramic glaze.
I made a quick room scene in MoI and render was done in Metropolis BiPT.
If I'm able to wait longer, I'll be able to take care of much of the noise.
EDITED: 16 Oct 2012 by MAJIKMIKE
5470.22
And then there is this ... How close is this
Martin
Size: 340.3 KB, Downloaded: 179 times, Dimensions: 792x532px
Size: 447.5 KB, Downloaded: 183 times, Dimensions: 792x532px
5470.23 In reply to 5470.22
Nice! A motorcycle with a hitch mount...
I could support an 10m-80m High-Sierra Screwdriver with an ATAS and 100 watts barefoot. ;-)
And do it in style!
5470.24 In reply to 5470.23
Here is a unique object produced from a similar process.
This one started off as a Revolved-by-Rail cylinder made with a grid of 24x18 control points.
Some odd points were scaled in, while evens were scaled out to even the outside.
An inner circle was trimmed in the Z direction to 'gut' the inside shapes, then I used Twist.
Could be an old push-mower blade, or some kind of exhaust grate.
5470.25
Here is a really nice render done by Ed Ferguson in KeyShot.
5470.26 In reply to 5470.25
Looks clean, give Ed a pat on the back from me
Martin
5470.27
Really nice. Reminds me that I don't know even half of the program's features or power.
C.
5470.28
Hallo,
I have more simple and elegant way to make this kind of rim.
Check this video:
http://www.youtube.com/watch?v=OjRA4_fYGbs&feature=youtu.be
5470.29
Thanks for the alternate method!
This underlying feature to NURBS surface design is what I was emphasizing: Don't forget that you can manipulate the surface structures.
...Moi3D is so versatile!
5470.30 In reply to 5470.29
5470.31 In reply to 5470.29
No problem you have good tutorials, i learn some tips form them)
5470.32
Hi Mike,
I finally found some time to go through your tutorial. I'm having a little issue with moving the nurb points. Take a look, there is no gradual transition between the points that have been moved and the the ones that are not. Did I miss something?
Size: 81.4 KB, Downloaded: 64 times, Dimensions: 919x736px
5470.33 In reply to 5470.32
Hi beanworks, can you please post the 3DM model file when you have a question about a problem with a particular shape like this? That makes it a lot easier to dig into it and see what's going on, it's much harder to diagnose geometry issues just looking at one screenshot where you can't zoom in and rotate around, etc...
Is it possible that your surface was created from a curve that was made up of multiple segments instead of only one single smooth segment? If so that could make that kind of result, the segmentation is basically transferred into the surface that's created from such a curve. Usually in a case like that you can fix that up by running the Rebuild command on the curve before using it for construction:
http://moi3d.com/2.0/docs/moi_command_reference10.htm#rebuild
That tends to be the easiest way to convert a curve made up of multiple segmented pieces into just one single smooth segment.
5470.34
Haha, Yep, thats exactly what I did. You're awesome, thanks.
5470.35
I'm so glad Beanworks - you spooked me! ;-)
Have fun!
5470.36
Here is a neat interactive model of my sports rim (from Sketchfab.com)
Wait a minute or two for it to load then just click and drag to manipulate the model.
<iframe frameborder="0" height="700" width="800" src="http://skfb.ly/m4ji3hedca?autostart=1&transparent=1&autospin=0.1&controls=1"></iframe>
5470.37 In reply to 5470.36
By Default tire is White!
So White on white there is nothing to view before you move the mouse!!!
And after click and move you see only the center of the rim!
Show messages:  1-17  18-37  38-46
