relative constraint with polylines drawing...
 1-7  8-27  28-31
547.28 In reply to 547.27
Seems Dürer has used massively circles helpers :)
in fact maybe "color layers background helpers" or similar will be also useful for drawing curves over a model?
EDITED: 23 Apr 2007 by PILOU
547.29 In reply to 547.27
>I'd be very surprised if the current system is not what artists expect - your message here is actually the very first complaint that I've heard about it!
Typically most people are more concerned about "up, down, left, and right" instead of "x,y,z".
The current system rotates objects to preserve what is considered the "up" direction.
Sorry I must be more specific here. I am talking about a 3d real time pipeline mainly. In such pipeline you export a geometry and you have to consider the complete orientation of the object not just the up direction. Look at this example, this is a car that I have done : the car is pointing in the positive Z direction and the driver is on the positive X side. So if I am using MoI to build a mesh ( the starting point ! ) I would need to transform the mesh in my "final"(-> export) software. This is a room for errors ( and this error can be difficult to see early in the process with a more "generic" type of mesh...) that won't be accepted in many companies...it may sound stupid but its true.
Most meshs from MoI won't be used for the final output but they will need to match the low polygon version(-> for backing :normal map, occlusion, ...). Another thing is the fact that MoI will be used as a starting point mainly.
>I guess I don't really understand what you would prefer instead
Actually you have 2 solutions ( not necessary for v1 ) :
* provide a more complete output.
*Allow us to build in the correct orientation right from the start-> Let me choose the "ground" plane ( and based on this choice, feature like vertical snap should follow of course ).
>yep straight snap ( vertical snap ) is what I was looking for, don't know why I have miss that..It's an old rhino feature too if I remember correctly. Tks for the info on the workflow with Clines and I can't wait for an arbitrary construction plane ( maybe in v2 )!
547.30 In reply to 547.25
Thanks, yes, rotate would have to be part of the orient2points, too, I didn't think of that. ;-)
Since I would usually be using it to place cross sections along two rails, maybe I can array
a certain number of them along the rails and then rotate and scale them for now.
-Jesse
547.31 In reply to 547.29
Almost - the old Rhino feature was similar but slightly different, it was called "elevator mode". If you held down the control key it would lock down the x,y point on the plane and let you track vertically off of the plane, and you used a different method ("ortho", activated with shift) to do straight lines in the x and y axes, but ortho did not snap in Z.
For MoI I really wanted to get away from using all those kinds of special modifier keys like Shift and Control, etc...
Yup, I think these will be a part of V2.
Show messages:  1-7  8-27  28-31
