I need help with a (seemingly) straightforward extrude
All  1-4  5-6
5454.5 In reply to 5454.1
Hi sneather, it sounds like you've got it all figured out now (thanks Marc!) - and yup usually the process for something non-planar is to trim out a surface piece and then use that surface with either extrude or shell since then you will get caps, you will only get caps on a curve extrusion if it's a planar closed outline.
http://moi3d.com/forum/index.php?webtag=MOI&msg=3024.4
http://moi3d.com/forum/index.php?webtag=MOI&msg=4010.4
http://moi3d.com/forum/index.php?webtag=MOI&msg=3318.1
Also here's an example that shows the difference between doing an extrusion versus doing a shell, they produce a different kind of result with the extrusion going straight in one direction while the shell producing an offset surface that moves along the original surface's surface normal at every point:
http://moi3d.com/forum/index.php?webtag=MOI&msg=4791.13
5454.6 In reply to 5454.5
Thanks, Michael, for the additional help.
But yes, indeed, Marc hit the nail on the head, right from the start.
I'm slowly getting to a point where I'm able to do more of the prep work on my clients' CAD files, than I had previously been able to accomplish. This has the potential to both increase the quality of my finished renders, and save me hours of trying to do the same thing in my animation system. So, enjoying MOI so far!
Cheers!
Show messages: All  1-4  5-6
