Thread cutting script - WIP
 1-7  …  28-47  48-67  68-87  88-107  108-110
5451.68 In reply to 5451.67
that does the trick.
Thank You.
5451.69
Iwant just to say I am experiencing the same problem ( I hadn't when using OSX...) on a notebook, win XP sp3
5451.70 In reply to 5451.69
Hi Fabri,
Are you using MoI version 2 on the notebook? I think this script needs v3, you can get the current v3 beta here: http://moi3d.com/beta.htm
5451.71 In reply to 5451.70
Yes I am running version 2 because notebook it is not mine… (my wife…) and I am really scared when installing/uninstalling some software under Windows…
I gave up. I like best to use MoI under OSX; less troubles; I hope…
However both files didn't work (the older and the younger). I feel there is some problem about interpreter files in Windows.
Thank you
5451.72 In reply to 5451.71
Hi Fabri,
If I remember right, both of those (the older and the younger) require MoI v3 in order to run, you just won't be able to run them using v2.
There isn't really any reason to be scared of installing the v3 beta, I mean it's just a newer version of MoI with more stuff in it, if you're using v2 it just means you're using old stuff...
5451.73 In reply to 5451.71
"""""and I am really scared when installing/uninstalling some software under Windows…""""""
The install is pretty much "standalone", which means it doesn't require anything special about windows. It will install in pretty much 6 seconds.
Just go for it!
5451.74
Wrote this script for myself. It's a rewritten version of the Martin's script.
EDITED: 7 Mar 2022 by SMIRNOV
EDITED: 17 Jun 2015 by PILOU
5451.76 In reply to 5451.75
Hi Max,
thanks for sharing, very handy.
Do you plan in future to add into script countersunk head for different screwdrivers ( hex, torx, PH1, PH2)?
Mik
5451.77
very convenient - thanks
5451.78 In reply to 5451.74
Excellent script Max, written by a true scripting master. I'm impressed by the preview possibility and the speed. Very useful. Thanks.
-Martin
5451.79
NutsAndBolts.v.0.95
Bugs fixed
Added ASME B18.2.1/B18.2.2 dimensions
5451.80 In reply to 5451.79
Tremendous script!
I'm having a problem with the very first running of the script, either with ShortcutKey, or Ext. Script.
Here is the first result:
Selecting another size then works fine.
Is there some setting to change?
5451.81 In reply to 5451.80
Hi Brian, it's looks like a decimal separator problem. I never used decimal numbers as default values in my scripts before. So I didn't knew about this problem.
I'll fix it today evening.
5451.82 In reply to 5451.81
Thanks Max
A bit over my head but:
So it is something to do with regional settings, ...culture settings, ...locale settings...
...Parsing numbers with a comma decimal separator in JavaScript...
My Moi .ini file has Distance Display = Decimal under [units].
(I recently read of such a "bug," in Geomagic Design I think, which was corrected.)
5451.83 In reply to 5451.82
fixed
5451.84 In reply to 5451.83
"""""""""fixed""""""
confirmed.....
If you ever get into this again, an "enhancement request" would be a metric/imperial radio selection to limit the options container to one or the other.... Obviously not something "wrong", just a suggestion.
Thanks again Max for sharing...
5451.85
Thanks, Max. You are truly a wonder...
Wonderfully competent and wonderfully generous!
5451.86
This is brilliant!! Many thanks to Max.
How feasible is a Gear, Spring or bearing script? I think there is already a gear script out there but to have things like different tooth profiles and and bevel options and other related options would be something else. Something like this but for MOI - http://geargenerator.com
BTW I admire your generosity to the forum, but i can appreciate that this must take up considerable time. I personally would pay $10 - 20 for these highly developed scripts
Matt
5451.87
hi Max
this is such a need script. i wonder if you plan to add different heads like sucket cap or countersunk head for different screwdrivers ( hex, torx, PH1, PH2) in the future?
Show messages:  1-7  8-27  28-47  48-67  68-87  88-107  108-110
