Thread cutting script - WIP
 1-16  17-36  37-56  57-76  …  97-110
5451.17 In reply to 5451.16
Hi Martin, to do a curve fillet you need to create a list with a boolean entry for each vertex and add that to the factory on input 2.
Normally this is done in the Fillet command by calling factory.generateVertices(), then letting the user pick the vertices which are temporary point objects and then calling factory.finishedPickingVertices() at the end of the picking stage, but you can instead directly create a list and add the boolean flags to it, there should be one flag for each segment of the input curve.
So something like this should work:
    factory = moi.command.createFactory( 'fillet' );
    var vertflags = moi.createList();
    vertflags.add( true );
    vertflags.add( false );
    factory.setInput( 2, vertflags );
    factory.setInput( 0, moi.geometryDatabase.getSelectedObjects() );
    factory.setInput( 3, 1.0 );
    factory.setInput( 4, "circular" );
    factory.commit();
5451.18 In reply to 5451.17
Cool, thanks a lot for the help. I would have never got this to work.
5451.19 In reply to 5451.13
Michael, re: script timeout.
When I was calculating "fibonacci" points with a fibonacci script with nested For Loops, after about
12,000 points, MoI would quit working. I was wondering if this may have been due to this "script timeout" ?
Or maybe it was some kind of memory used up thing?
Thank you,
Brian
5451.20 In reply to 5451.19
Hi Brian, yeah most likely that was hitting the timeout as well, it will be disabled in the next v3 beta.
12,000 points is not really that much memory so it's more likely that it was the same timeout problem.
5451.21 In reply to 5451.20
Thank you Michael.
Tip of the day for Windows7: After downloading a few hundred woodworking files, "clear the download list," to maintain the speed
with which the download window pops up.
5451.22 In reply to 5451.20
Sorry for asking again but here's another obstacle:
This script
script:
/*draw cylinder*/
var factory = moi.command.createFactory( 'cylinder' );
factory.setInput( 1, moi.vectorMath.createFrame() );
factory.setInput( 3, 20 );
factory.setInput( 4, moi.vectorMath.createPoint( 0, 0, 40 ) );
factory.commit();
moi.geometryDatabase.selectAll();
/*chamfer edges*/
factory = moi.command.createFactory( 'chamfer' );
factory.setInput( 3, 1 );
factory.setInput( 4, 1 );
factory.commit();
chamfers both ends of the cylinder.
How do I persuade the above script to chamfer just one end?
Input 2 of the factory is a corners list according to the Morrill documentation. You showed me how to select vertex points and that this list actually contains boolean switches. Here I have to select surfaces or Breps, correct?
5451.23 In reply to 5451.22
Maybe de-select a face? EDIT: (or edge)
Try interactively to see what is needed.
Just a thought, how about a flow, to reduce thread depth at head end?
EDITED: 8 Oct 2012 by BEMFARMER
5451.24
Hello,
This looks very interesting. If I am reading correctly UTS and metric threads follow the same ratio rules, so it might be possible to create a script that would allow for nearly all types of UTS and metric sizes. Is your cutting script ratio based or does it use hard coded values? Thanks.
http://en.wikipedia.org/wiki/ISO_metric_screw_thread
5451.25 In reply to 5451.22
Hi Martin,
You'll need to have a sub-object of the brep object to be the input into the chamfer command.
The way chamfer works (you can just use the command to check it out) is that if you have a whole object selected it will chamfer all sharp edges that it can find in the object. If you want to limit the chamfer to only one edge you can select either that edge or a face - selecting a face will target all the edges that belong to the face.
You can access a brep's sub-objects by calling the .getEdges() or .getFaces() methods on the brep object, these return object lists.
Right now with your current script snippet there, it looks like you've got the brep as the current selected object. So you'll need to extract the brep from the "object list" of the selected objects, get the edge or face that you want and then put that edge or face into a new object list and then set that as the input into chamfer.
Then with chamfer being given a face or edge sub-object it will then limit the chamfer to that particular area.
So it would look something like this (untested, may have typos):
// Get the cylinder brep object out of the selected object list.
var sel_list = moi.geometryDatabase.getSelectedObjects();
var cyl = sel_list.item(0);
// Get the first edge of the cylinder.
var cyl_edges = cyl.getEdges();
var first_edge = cyl_edges.item(0);
// Build a new object list with that edge in it.
var chamfer_list = moi.geometryDatabase.createObjectList();
chamfer_list.addObject( first_edge );
// Give the factory the object list with the edge in it as its input.
factory.setInput( 0, chamer_list );
EDITED: 8 Oct 2012 by MICHAEL GIBSON
5451.26 In reply to 5451.24
Hi Brian, I never used the Flow command before so I doubt I will be able to put this into a script at this time. In the current version I do the tapered helix/rail stuff in an extra step which only works when the threadlength is a multiple of the threadpitch.
Hi OSTexo, my script produces the metric thread profile you've linked to. Basically I generate a cutter object and cut the thread similar as it would be done on a lathe. The only variables required are the thread diameter, the thread pitch and the thread length. The rest is done automatically.
Hi Michael, thanks again for the quick and competent help. No typos, your script worked from the start!
I included it already and can now present another preliminary version of my script. For a good experience run it with the default values first. Just hit Start and the output should look like this:
Completely threaded rods are already geometrically correct for all thread lengths.
EDIT: I deleted the attachement and attached the newest version of this script to the first post of this thread.
EDITED: 13 Oct 2012 by MARTIN3D
5451.27 In reply to 5451.26
Thanks for developing and sharing the script, Martin - the results are looking great!
Seems beautiful result!
5451.29
Hello Martin,
Really cool stuff. How did you manage to knock off the two sides of the triangle that are perpendicular to the cylinder before the cutting operation? I never could get that to work without knocking off the edges so there wouldn't be that sort of self intersecting situation and the cutting surface wasn't skimming to closely to the cylinder. Of course that was a manual operation, perhaps the scripted operations behave differently?
5451.30 In reply to 5451.26
Wicked!! I'de like to see this developed to include inches and other variations.
Thanks Martin.
5451.31 In reply to 5451.30
Thanks to all. UNC threads should be no problem as they seem to have the same geometry as Metric threads: http://en.wikipedia.org/wiki/Unified_Thread_Standard. Other threads e.g Acme will require a different cutter shape.
I'm satisfied when the final version of this script can make make metric normal and fine threads plus UNC and UNF.
I imagine
- a dropdown list where the different threads like "M6 x 1" or "1/4 UNC" can be chosen
- a input field for the thread lenght (which has to be slightly corrected by the script to allow full turns)
- a input field for the length of the not threaded part
- if that is possible by scripting the MoI units will be set to mm
I agree OSTexo making a cutting object that actually cuts as wanted is tricky. If the sweep overlaps or touches over a wider area you're out of luck.
I do it like shown below. The height of the cutting object is equal to the thread pitch and the sweeped profiles only touch at one edge.
The final trick to make this work was to move the profiles out by a tiny amount so the the boolean diff operation sees some difference.
I use 0.1 mm at the moment but I just checked that 0.01 mm seems to work too.
5451.32 In reply to 5451.31
I don't know if this makes sense but I wonder if its possible to kind of "boolean union" an object (e.g. a self intersecting sweep) by itself i.e. remove any overlaps and make it one solid object.
5451.33 In reply to 5451.32
Hi Martin,
> solid object.
I guess it could be possible in some situations, but it would definitely require a lot more work done to get something that would work well.
Many kinds of self intersecting surfaces are also poorly formed in the intersection area with things like lumpy ripples and not an actual totally clean self intersection even.
5451.34 In reply to 5451.33
it would be handy in a situation like this where profile, rail and sweep are generated cleanly by script and the Boolean Diff still doesn't work because the sweep profile is intersecting or touching over a larger area. I could then use the cutter profile below for example which just doesn't boolean diff when sweeped because its touching over a larger area I guess. If I could "bake" this sweeped cutting object into one firm solid it would work in the Boolean Diff operation.
I updated the script from yesterday. It now corrects the thread length slightly to allow full turns so it produces correct results for any settings.
EDITED: 8 Oct 2012 by MARTIN3D
5451.35 In reply to 5451.34
Hi Martin, from what you're showing there that's not quite a "self intersection" like when a surface is actually crossing back over its own self.
What you're showing there is more of a "edge overlapping" intersection. Those can work ok if you've got pretty precise geometry, like for instance doing a union on the attached 3DM file seems to work ok.
But when you have something that has edges barely grazing each other and it's constructed from some kind of fitting process like sweeps, what can happen is that in actuality the edge is sort of barely wiggling back and forth above and below the surface and that kind of thing becomes quite difficult for the intersector to get a clean intersection from.
5451.36 In reply to 5451.35
I attached an example. The 2 mm high profile is generated and placed by a script. The helix pitch is 2 mm. So the profiles just touch when sweeped. The sweeped cutting objects sticks completely into the cylinder so there are no edges sort of barely wiggling back and forth above and below the surface. Still when you boolean diff the cylinder with the sweep it gives no result. Why?
Show messages:  1-16  17-36  37-56  57-76  77-96  97-110
