Center model on world axis zero coordinates?
All  1-7  8-17
5427.8 In reply to 5427.7
oi martin!
as they are commands, you just have to put
Shift+C=BoundingBox or
Shift+C=BoundingBoxCenter
in.
- marco
5427.9 In reply to 5427.8
Thanks Marco, I thought it is possible to run two comands at once. My bad.
5427.10 In reply to 5427.5
>The button will say something like "From center" or "From bounding center" or something like that
Michael, may I suggest "Pick center of bounding box" or "Pick bounding box center".
5427.11 In reply to 5427.10
Hi Martin,
The tricky part about button text (text going inside an actual push button) is that when it's pretty long it can easily wrap to multiple lines in that narrow side pane area...
I don't worry about that so much with prompt text (the description at the top of the command area that tells you what MoI is expecting for you to enter next), but for push button text it's kind of good to try and make it shorter.
5427.12
Am I wrong or is this what you're looking for ? Center at Origin
http://moi3d.com/forum/messages.php?webtag=MOI&msg=2409.2
And by the way, Michael, is it possible to modify the script to have a "Put on Ground" option ? So that the bottom of the bounding box is automatically placed on the CPlane. (There's a similar tool in Wings3D)
EDITED: 27 Sep 2012 by SCHBEURD
5427.13 In reply to 5427.12
Hi Bernard, I forgot about that previous script, I think that should be a useful shortcut for what Martin is talking about.
It's not easy to add an option to that previous one since it has no UI, it just immediately does an action and then exits.
But I've attached a separate "PutOnGround" command here which you can use instead.
5427.14 In reply to 5427.13
PutOnGround works really well !
Thanks a lot. I will use this one very often !
Happy MoI user since beta version of August 13 2006...
PutOnground : cool
But no possibility to stop the drop if there is an objet on the path ? (like collision)
5427.16 In reply to 5427.15
Nope, this is just a simple positioning script, something that would do comprehensive collision detection would be a much more involved project.
5427.17 In reply to 5427.16
No problem :)
Show messages: All  1-7  8-17
