Nice Shaders...
All  1  2-14
5423.2 In reply to 5423.1
Hi Rich, you can get a good smooth NURBS-looking result from a meshed result if you get vertex normals used to shade the polygon mesh.
The most common way to get that is to use OBJ format for the export out from MoI, when MoI exports to OBJ format the vertex normals included at the corners of every polygon come from the original NURBS surface and they're used for the shading and that greatly helps the polygons to look the same as the original NURBS model, they really make a big difference.
So getting vertex normals coming through would be the main thing to look for.
5423.3 In reply to 5423.2
Hi Micheal,
Thanks but correct me if I'm wrong but if I wanted to apply a colour gradient to this surface, because it's a mesh the gradient wont be smooth (because the surface has been is 'pixelated' as it were by the creation of n-gons?)
It's difficult for me because I don't know the technical terminology - apologies.
I guess what I would be looking for would be a way to apply custom shaders to surfaces...
- Rich
5423.4 In reply to 5423.3
Hi Rich,
here's an (old) example from a modo Artist (sorry don't remember her name) were she used gradients on a polygon mesh (28.000 quads) as you can see the surface is smooth. The only thing, if i'm not mistaken, is you have to watch out for the export settings in MoI (density of polygons) if you really want to print really high resolution images, to see not a "facetted" look. You may have to create also a UV map in your 3D app to apply for example color gradients from images to your surface. Or as you mentioned use shaders in your 3D app, which provide color gradient creation functions.
5423.5 In reply to 5423.4
Its Laura Lediaev ;)
http://www.modsimviz.com/
All of the images displayed were rendered (ray-traced) with either Luxology Modo or Maxwell Render. C++ programs were written to create/process the meshes for the geometry, and scripts for importing the scenes into Modo.
5423.6 In reply to 5423.4
Sweet - I'm going to give it a try with as many quads as I can handle!
- Rich
5423.7 In reply to 5423.3
Hi Rich,
There isn't really anything special about NURBS compared to polygons when it comes to regular shaders being applied, you should be able to apply a color gradient shader to a polygon mesh object in the same way that you would have applied to to NURBS output, and in fact most likely anything you'd be doing with NURBS would actually be converting it into polygons when it did the actual rendering.
I guess it could depend on the specifics of the shader that you're using though. But if it's a procedural shader that just works off of 3d point positions though that would work fine with polygons.
5423.8 In reply to 5423.7
Hmmm - the amount of quads I'm having to make is making everything super sluggish, and I'm still getting lines in the render (vray) - arg!
Question: in the viewport window (native to MoI) - the way the geometry is rendered out, you get a smooth transition between highlights and shadow - how does this work exactly?
- Rich
5423.9 In reply to 5423.8
Why does the object have to be a mesh for a gradient to be applied? Confused!
- Rich
5423.10 In reply to 5423.9
1280x960 - if this was blown up, definite quad-mare (and the file is 64 meg)...Damn those quads :)
Size: 74.6 KB, Downloaded: 40 times, Dimensions: 631x467px
5423.11 In reply to 5423.8
Hi Rich,
That uses a technique called Gouraud shading:
http://en.wikipedia.org/wiki/Gouraud_shading
Under regular Gouraud shading colors are calculated at each polygon vertex and then when the polygon is drawn an interpolation is used that blends between the colors at the vertices.
Are you possibly doing your shading only with each individual polygon being a separate color? If so then that's the problem - you want to instead use some kind of interpolation mechanism like Gouraud shading or some kind of procedural shader so that color is calculated at a much finer level like per indiviudal output pixel rather than only one color for a whole single polygon.
5423.12 In reply to 5423.9
Hi Rich,
Sorry I don't quite understand what you are referring to here - you're talking about some other software here and not MoI in particular, is that correct?
5423.13 In reply to 5423.12
Yes sorry I was Michael - Rhino via Grasshopper. In that case, it appears that each polygon has a different colour within the mesh. I think Gouraud was what I was getting at, the gradient has to be interpolated to give a smooth look...I don't quite know how to approach this predicament! Does anyone know of any softwares that will allow me to play around with such shading using open nurbs objects (pipe dream)?
This is all very interesting thank you!
- Rich
5423.14 In reply to 5423.13
Hi Rich, look for things like "false color" or "vertex colors" something like this:
http://geometrygym.blogspot.com/2011/09/mesh-false-color.html
You want something that will let you specify colors per _vertex_ rather than a per _face_ color value.
Most mechanisms that allow you to supply color information at the per-vertex level will also handle interpolating the colors along the interior of the polygons that connect the vertices.
Show messages: All  1  2-14
