Render software to be used with MOI
 1-15  16-35  36-40
Top renderings ! ;)
5422.17 In reply to 5422.10
> My guess is, since you've mastered MoI, you'll be into 3D modeling professionally soon.
Thanks Ed!
I feel good wisdom in your admonition.
Adamio.. Wow, nice examples!
...Does anyone know if Thea Render work with the GPU yet?
EDITED: 25 Sep 2012 by MAJIKMIKE
5422.18
Thanks for all the replies.
What I need to render usually are small plastic housewares.
I have tested Octane and works very well. There are some fireflies but maybe is a matter of illumination adjustment. MOI .obj files work very well as far as I have tested and the price is really good. There is also a very nice turn table animation feature. On the other hand you cannot cast shadows on HDR environments.
Thearender works also very well. The price is a lot higher than Octane but still a lot cheaper than Keyshot. Thea has shadow cast materials so you can use them with HDR environments. Thea can do animations also.
Is hard to choose between Octane and Thearender.
Have any one try Arion render?
Axel
5422.19 In reply to 5422.18
I just bought Arion for a discounted price as a Fryrender customer
Arion use all GPU and CPU's of your hardware (hybrid)
It deliver unbiased results or,if you want,you can save rendering-time switching to -draft-mode( a faster solution close to unbiased)
I use it preparing my scene in C4D R10.5 with my Fryrender plug-in to export the scene in that format then open it in Arion,so i can't say how it works importing directly Obj files
you can choose what video card will work for computation and how many cores of Cpu will work too,leaving some free hardware's power to modify your scene if you want
If you think to do an heavy-use of it you must have two videocards,like i told in my previous thread(an high number of CUDA cores and at least 1Gb video memory)
If you are a Max or Xsi user you also have LIVE plug-ins and animation
...sadly Randomcontrol have decided to "kill" all others export plug-ins(C4D-SKP-MODO-RHINO-MAYA)..and Fryrender too !
anyway i'm an- unbiased rendering- supporter,so my suggestion is choose one of them
5422.20
Hello,
I have used Thea to see how clear PMMA parts would look (under 10mm in size) prior to production. Taking the parameters from material data sheets, the renders were very accurate when compared to actual parts.
5422.21 In reply to 5422.20
It's probably got something to do with the particular rendering engine being "unbiased", but I'm unsure myself.
I notice that if I give Metropolis Light Transport mode (TR2 in Thea) enough passes in Keryky, even the most tiny detail will be captured, but at the expense of time and the graininess factor. Also the number of polygons given to the smaller details will affect reflection detail as well.
More polys kill render time though.
I know some modes I've tried will make cleaner broad surfaces with little noise but have issues with tinier details.
Some render engines are better with rendering globally illuminated objects, and some modes are better with caustics and indoor light elements.
5422.22
It sounds like you are approaching the search sensibly,
It is worth trialing as many as you can. TR2 in Thea is a little different to MLT in Kerkythea though.
Intergration of GPU in Thea is on the horizon.
Usually you wait a little for the implementation of features in Thea but to me the benefit is that when it is implemented it is a finished fully functioning high quality product.
For me the big benefit of Thea is the material creation system. It seems very logical and well laid out to me, designed for the user just like MOI.
5422.23
I use to have a snobby attitude towards Blender. But the new version is pretty usable. It works with a range of renderers. But I'm even impressed by the new internal ones. Check this out.
http://blendernews.org/xe/?mid=Feature_Articles&document_srl=1274
While the rendering may be capable, it seems there are issues importing MoI OBJ files. If you get over that hurtle the best renderer may be a free one…
As for the scale of your objects, why not cheat? If the renderer you choose can’t do small stuff scale it up.
their last movie ( a little hard to follow the story :)
By Blender Foundation
5422.25 In reply to 5422.23
Hi Shaun,
Actually the issue is that Blender doesn't do very well with importing OBJ files from any CAD program, not just something specific to MoI in particular.
The problem is that they just ignore the "vertex normals" information in the OBJ file - that data in the OBJ file is not read in, and there are also various other problems with vertex normal handling in Blender as well like even if they are read in they get discarded at render time.
See here for some previous discussions on this:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5083.6
http://moi3d.com/forum/index.php?webtag=MOI&msg=4515.3
http://moi3d.com/forum/index.php?webtag=MOI&msg=4272.1
http://moi3d.com/forum/index.php?webtag=MOI&msg=4409.79
The omission of vertex normals import makes it pretty difficult to get high quality renders of CAD data in Blender. Every other rendering program that I'm aware of does not have this particular problem, but it has been an issue with Blender for a really long time now.
So if you need to render CAD-generated polygon data such as the data exported from MoI, Blender does not really work particularly well for that right now because of this particular limitation in it. You can get the raw polygon data into it but when the polys are shaded you will likely have various kinds of shading artifacts that sort of "leak" some resemblance of the polygon structure into the rendered result. Those kinds of artifacts do not happen at all when the vertex normal data that's included in the OBJ file is used for doing the shading, so you really want to use a renderer that is able to import and use that data instead of ignoring it.
5422.26
You can make blender work it you don't mind doing a little hand work. The way I have done it in the past is export it as a NGON without welding the mesh. this removes the problems around the joins (as it isn't joining) but there are usually still some problems on rounded areas but If you go around the mesh and remove the small triangles you can get nice looking meshes out of it. it's not ideal as it would be nice if you could just do an import and be done but it is free And I have had to work out making MAX work nicely with MOI as well so....
Val
5422.27 In reply to 5422.26
Hi Val, yes but at least with Max the problems you are running into there have been solved in more recent releases than the one you're using.
5422.28 In reply to 5422.27
My point was more that there is always a bit of tweaking when you go from platform to platform.
An example of a direct import of an OBJ from MOI to Blender is the attached image. I didn't anything other than remove the material it comes in with and add one that shows off flaws. I think it looks pretty good.
EDITED: 30 Jan 2022 by VAL2
5422.29 In reply to 5422.28
Hi Val,
But for a lot of programs there is no tweaking at all required - in most other rendering programs where vertex normals come through properly it usually totally avoids all of the types of glitches that you were describing needing to do workarounds for.
That does look pretty good - you can have a lot more leeway on getting imperfect shading if you're not really zoomed in very close to any one particular part of the model.
5422.30 In reply to 5422.29
I just repost this problem to the Blender team
Wait and see :)
AHH bad news from the Blender Team!
No new work about "vertex normal" in Bender! :(
5422.32 In reply to 5422.31
Too bad.... It's a pretty big area where Blender is really far behind everything else.
5422.33 In reply to 5422.32
Is anyone using Arion 2 for rendering?
I am particularly interested in architectural capabilities and ease of use.
cheers,
eric
5422.34 In reply to 5422.19
Hi m-dynamics,
>It deliver unbiased results or,if you want,you can save rendering-time switching to -draft-mode( a faster solution close to >unbiased)
I recently saw that RandomControl now offers also a learning edition of Arion 2. My questions, if you don't mind, are does Arion's license allow you to install it on two machines, because i would like to set-up my scenes on my iMac (Win XP) and later render them on my Notebook (Win 7), which outperforms GPU wise my iMac.
Can the preview rendering mode, which i saw on a youtube demo, be turned of, like working in Maxwell Studio, prior rendering?
And last but not least does Arion 2 comes with a (good) material library?
Any help would be greatly appreciated!
5422.35 In reply to 5422.34
I'd like to know a bit more about the standalone Arion 2 too :)
-- shapenoid.com
Show messages:  1-15  16-35  36-40
