Array on a spline with some randomisation
 1-13  14-33  34-53  54-66
5416.54 In reply to 5416.53
Yes.
I did have a previous version 2.5 I believe which since I have removed.
5416.55 In reply to 5416.54
I have another command that doesn't work either: QuickCircle. When I reassign that my key to the Previous command Randomize. It shows up with that error message but it is using QuickCircle as name in error.
5416.56 In reply to 5416.52
Hi Mike, so from what I can tell on your most recent screenshot there is that your keyboard shortcut now looks ok but your commands directory looks strange - have you accidentally made a second copy of the commands folder in a different location? Because your screenshot seems to be showing it under drive_c/commands, while MoI's actual commands folder is located under drive_c/moi/commands.
So the problem is that you're not getting into drive_c/moi/commands which is where you need to put the 2 files.
Please try the following steps:
Step 1 - right click the MoI .app icon and choose "Show package contents".
Now a finder Window will pop up with 4 things showing on it (initially at least, if you have expanded the "Contents" folder previously there will be a lot more showing - in this case collapse the Contents folder back down again so you only have the 4 initial things showing again), which are: Contents, docs, drive_c, and Wineskin.
Step 2 - double click on drive_c.
You'll now have 4 different things showing: moi, Program Files, users, and windows.
Step 3- double click on moi.
You'll now have a bunch of things showing and second from the top is commands.
Step 4 - double click on commands.
Now you are at MoI's commands folder - this is where you need to copy the files for any downloaded plug-in files.
Somewhere along the line I guess you must have accidentally copy/dragged the whole commands folder to a different location, so now you have 2 of them (copied one in drive_c/commands and original one in drive_c/moi/commands), one of which MoI doesn't know anything about or do anything with and so if you copy files into that unused one it will not be recognized by MoI.
Hope this straightens things out, please let me know if you are still stuck.
5416.57 In reply to 5416.56
I think I may have a super mess going. How can I find the commands folder and put it where it needs to go or would it be better to clean house reinstall Moi3D_3.1 and replace all of my commands into the newly reinstalled structure. A from scratch approach.
5416.58 In reply to 5416.57
Hi Mike, well does MoI run ok for you like if you click on the Line command can you draw a line?
If so then you're probably not really very messed up, you still have the original commands folder and you just have an additional extra one somewhere else that's not doing any harm other than not doing anything if you try to copy plug-ins there.
So if you're running ok you already have a commands folder where it is supposed to be, you can delete the additional one under drive_c/commands and leave the original one under drive_c/moi/commands .
If your main commands folder was completely missing you'd definitely notice big problems, almost nothing would work.
To get to the original commands folder, right-click on the .app and choose "Show package contents", then double click drive_c then double click moi then double click commands.
5416.59 In reply to 5416.58
Let me think about this. Your help is outstanding. I suppose this points out some pitfalls for users like me that aren't aees good at maneuvering some structure complexities.
It's seems difficult for me but I am getting through it because of your patience. Your personal customer service is notable to say the least!!
5416.60 In reply to 5416.59
No problem Mike, and yes I do want to make plug-in installation simpler in the future.
Do other regular commands like Line for example work ok for you right now?
If you're still stuck you can send me an e-mail and I'll arrange a time to do a remote-control screen sharing session with you so I can get your installation sorted out.
5416.61 In reply to 5416.60
Wow! I'll get back with you as soon as I can. Love your product!!
5416.62 In reply to 5416.61
I took the path of least resistance and I reinstalled MOI. Then I followed you directions as to installing the commands, including Randomize. I even set-up the CustomUI again.
I seemed to be ok and back running. As simple as this process probably was I struggled. Because I persevered I think I now have the process down. Because you were there to assist and teach me it helped me stay with it. Thanks again!
5416.63 In reply to 5416.62
No problem Mike, I'm glad you are all set up now!
Seems Undo not effective ?
5416.65 In reply to 5416.64
I've made a tuneup to fix that up, there is a new version here:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5416.5
5416.66 In reply to 5416.65
Perfect now!
Show messages:  1-13  14-33  34-53  54-66
