Array on a spline with some randomisation
 1  2-21  22-41  42-61  62-66
5416.22 In reply to 5416.20
< Undo doesn't work, a preview button maybe?
Works for me ;)
5416.23 In reply to 5416.20
Hi Marc, yup I thought about having a checkbox for a quick enable/disable of each section, and an "Update" button as well but I didn't think I would have enough time to finish those last night so they didn't make the initial cut.
I may be able to do some more work on it tonight to make some more refinements like that.
An x,y,z control for scaling should be feasible too, all good ideas!
I've updated the Randomize.zip attachment on the previous message with a new version of Randomize:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5416.5
New functions are a checkbox for each section so that you can disable a section by unchecking it without needing to reset all the values to null operations if you've already previously used Randomize in the same modeling session, and also x y z controls on the scaling to allow for either a uniform 3D scale, a 2D scale or a 1D scale only.
Also since there is non-uniform scaling now allowed I've changed the order to be Move, Scale, and then Rotate since doing a non-uniform scale will produce different results if you do it before the rotation as compared to after it:
Here's an example with only z scaling enabled:
On the left, Randomize has been run twice, first with z rotation of max 180 degrees, second with x and y rotations of max 55 degrees.
On the right, Randomize has been run once, with x, y, and z rotations of max 55 degrees.
Which side is better?
Now for the Move we have that (said 5 was enter)
-5 to 5 possible
Does it possible to have something for the Move like this
0 to 10 so a "direction" of the Move :)
Of course I can "move" the first result but ...
EDITED: 21 Sep 2012 by PILOU
5416.27 In reply to 5416.25
For me, the one on the right is better, but this is limited to the top view we see. Maybe a perspective would change that perception.
5416.28
This so rad ! Thanks for the work Michael !
It's expanding MoI features a lot :)
-- shapenoid.com
<< Which side is better?
A real random gives some groups! ;)
And not the right one image! ;)
5416.30
Had to do a quick one using the Randomize script.
The year is 2035 and the world is over populated.............this is Sky City 001.
Size: 1.1 MB, Downloaded: 101 times, Dimensions: 1920x1080px
5416.31 In reply to 5416.26
You could get this by editing the Randomize.js script - find the spot with:
function MoveObject( obj, move_dist, move_x, move_y, move_z )
	var dx = !move_x ? 0.0 : RandLerp( -move_dist, move_dist );
	var dy = !move_y ? 0.0 : RandLerp( -move_dist, move_dist );
	var dz = !move_z ? 0.0 : RandLerp( -move_dist, move_dist );
And then replace the -move_dist values with 0, like this:
	var dx = !move_x ? 0.0 : RandLerp( 0, move_dist );
	var dy = !move_y ? 0.0 : RandLerp( 0, move_dist );
	var dz = !move_z ? 0.0 : RandLerp( 0, move_dist );
Then I think it will have the directional behavior that you're asking about.
5416.32 In reply to 5416.31
Cool, that works like a charm!
Just what is the syntaxe for put
the ancient code as "quote" for remember the next time is i want to change it ?
Unlucky there is not notation in this one file but seeing in other JS I Suppose that is "//" ? ;)
For anyone doing these kinds of random, but structured "particles" on a regular basis, take a look at Element 3D.
Element 3D is a plug-in for Adobe After Effects. It's a particle array system using 3D objects.
I've been using it with my MoI models exported as OBJ.
Although it handles arrays, it is used a lot for animating just a single 3D model in a faster, simpler way than using a full blown 3D system like Cinema 4D.
After Effects is of course primarily for motion graphics, but because it has so much overlap with Photoshop it gets used for still images as well.
Ed
http://www.videocopilot.net/tutorial/3d_replicator/sd/
http://www.videocopilot.net/tutorial/screen_animations/
http://www.videocopilot.net/help/element/tutorial/basic/animation_engine/
5416.34 In reply to 5416.32
Hi Pilou, you can "comment out" script code by either putting // characters at the start of each line, like
// code here
// code....
// etc....
or also you can do a whole block by putting /* */ around the whole block like:
a bunch of code here
etc...
etc...
5416.35 In reply to 5416.30
"""""""""""The year is 2035 and the world is over populated.............this is Sky City 001.""""""""""
Your not just a table guy with helpers... You have the artist thing. I love your side stuff. :o
5416.36 In reply to 5416.34
thx!
for the /*a bunch of code here etc...*/
That will be in another life :)
5416.37 In reply to 5416.35
Thanks Burr,
It was just something that popped up in my head when Michael released the script, it didn't take long and imagine what it would take to do that without the Randomize script.
5416.38
It's a lot of fun.
I was able to easily create.
Message 5416.39 deleted 23 Sep 2012 by MORITAKA
5416.40 In reply to 5416.38
I like this one, Moritaka .... Well done
Martin
5416.41 In reply to 5416.40
Thanks for the update Michael!
Marc
Show messages:  1  2-21  22-41  42-61  62-66
