Array on a spline with some randomisation
 1-15  16-35  36-55  56-66
Here is a Top View of an array of flat "diamonds," on which Michaels new script Randomize has been applied,
with a maximum angle of 55 degrees. This way edge on views are avoided.
I was going to claim that z axis rotations up to 180 be allowed, with y and x about 55 degrees, but upon reconsideration, am probably mistaken.
One think about randomized, is that the results are non-reproducible.
EDITED: 18 Mar 2017 by BEMFARMER
Size: 49.5 KB, Downloaded: 45 times, Dimensions: 170x167px
Very funny!
Will work fine also with Scale Array ;)
EDITED: 26 Apr 2020 by PILOU
5416.18 In reply to 5416.12
Hi DesuDeus, you're welcome and I'm glad that will be useful for you!
And congrats on the job with Moët & Chandon too, that sounds like some pretty cool work you've got lined up!
5416.19 In reply to 5416.14
Hi Danny,
> how many of you would you need to help out with all the requests?
I've got enough stuff lined up that I'm pretty sure I could keep at least 10 busy! :)
5416.20 In reply to 5416.19
This really made my day, I was searching for a quick way to make an abstract floor pattern...
Some small details:
Quick switch to enable/disable rotate, scale or move without clearing all fields
Undo doesn't work, a preview button maybe?
It could be nice to have xyz constraints on the scale factor like rotate and move, say you want to generate a landscape of buildings and have different heights.
Marc
5416.21 In reply to 5416.19
""""""I've got enough stuff lined up that I'm pretty sure I could keep at least 10 busy! """"""""""
Send 1 on permanent vacation. Give 8 to JG. And leave 1 working here with us!
5416.22 In reply to 5416.20
< Undo doesn't work, a preview button maybe?
Works for me ;)
5416.23 In reply to 5416.20
Hi Marc, yup I thought about having a checkbox for a quick enable/disable of each section, and an "Update" button as well but I didn't think I would have enough time to finish those last night so they didn't make the initial cut.
I may be able to do some more work on it tonight to make some more refinements like that.
An x,y,z control for scaling should be feasible too, all good ideas!
I've updated the Randomize.zip attachment on the previous message with a new version of Randomize:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5416.5
New functions are a checkbox for each section so that you can disable a section by unchecking it without needing to reset all the values to null operations if you've already previously used Randomize in the same modeling session, and also x y z controls on the scaling to allow for either a uniform 3D scale, a 2D scale or a 1D scale only.
Also since there is non-uniform scaling now allowed I've changed the order to be Move, Scale, and then Rotate since doing a non-uniform scale will produce different results if you do it before the rotation as compared to after it:
Here's an example with only z scaling enabled:
On the left, Randomize has been run twice, first with z rotation of max 180 degrees, second with x and y rotations of max 55 degrees.
On the right, Randomize has been run once, with x, y, and z rotations of max 55 degrees.
Which side is better?
Now for the Move we have that (said 5 was enter)
-5 to 5 possible
Does it possible to have something for the Move like this
0 to 10 so a "direction" of the Move :)
Of course I can "move" the first result but ...
EDITED: 21 Sep 2012 by PILOU
5416.27 In reply to 5416.25
For me, the one on the right is better, but this is limited to the top view we see. Maybe a perspective would change that perception.
5416.28
This so rad ! Thanks for the work Michael !
It's expanding MoI features a lot :)
-- shapenoid.com
<< Which side is better?
A real random gives some groups! ;)
And not the right one image! ;)
5416.30
Had to do a quick one using the Randomize script.
The year is 2035 and the world is over populated.............this is Sky City 001.
Size: 1.1 MB, Downloaded: 113 times, Dimensions: 1920x1080px
5416.31 In reply to 5416.26
You could get this by editing the Randomize.js script - find the spot with:
function MoveObject( obj, move_dist, move_x, move_y, move_z )
	var dx = !move_x ? 0.0 : RandLerp( -move_dist, move_dist );
	var dy = !move_y ? 0.0 : RandLerp( -move_dist, move_dist );
	var dz = !move_z ? 0.0 : RandLerp( -move_dist, move_dist );
And then replace the -move_dist values with 0, like this:
	var dx = !move_x ? 0.0 : RandLerp( 0, move_dist );
	var dy = !move_y ? 0.0 : RandLerp( 0, move_dist );
	var dz = !move_z ? 0.0 : RandLerp( 0, move_dist );
Then I think it will have the directional behavior that you're asking about.
5416.32 In reply to 5416.31
Cool, that works like a charm!
Just what is the syntaxe for put
the ancient code as "quote" for remember the next time is i want to change it ?
Unlucky there is not notation in this one file but seeing in other JS I Suppose that is "//" ? ;)
For anyone doing these kinds of random, but structured "particles" on a regular basis, take a look at Element 3D.
Element 3D is a plug-in for Adobe After Effects. It's a particle array system using 3D objects.
I've been using it with my MoI models exported as OBJ.
Although it handles arrays, it is used a lot for animating just a single 3D model in a faster, simpler way than using a full blown 3D system like Cinema 4D.
After Effects is of course primarily for motion graphics, but because it has so much overlap with Photoshop it gets used for still images as well.
Ed
http://www.videocopilot.net/tutorial/3d_replicator/sd/
http://www.videocopilot.net/tutorial/screen_animations/
http://www.videocopilot.net/help/element/tutorial/basic/animation_engine/
5416.34 In reply to 5416.32
Hi Pilou, you can "comment out" script code by either putting // characters at the start of each line, like
// code here
// code....
// etc....
or also you can do a whole block by putting /* */ around the whole block like:
a bunch of code here
etc...
etc...
5416.35 In reply to 5416.30
"""""""""""The year is 2035 and the world is over populated.............this is Sky City 001.""""""""""
Your not just a table guy with helpers... You have the artist thing. I love your side stuff. :o
Show messages:  1-15  16-35  36-55  56-66
