Boole fails
All  1-6  7-9
5412.7
Hello,
You could also try creating the curve framework using a copy of the rectangle, Helix command, Network each face, Join, then Planar to cap the ends. It results in a better cutting surface with less end ripple. The original is in grey, the Networked in orange.
Boolean
Ripple
EDITED: 3 Feb 2025 by OSTEXO
5412.8
Hello,
You can further reduce the ripple by rebuilding the construction curves with something like a tolerance of .001 prior to performing the Network command. The original is grey, Networked solid is orange, and the green solid had the Rebuild command run against the curves prior to the Network command.
Ripple 2
5412.9 In reply to 5412.8
Thanks to all of You, helped me a lot.
Show messages: All  1-6  7-9
