slf file format conversion
All  1-15  16-18
Little test :)
A rounded filleted triangle on the ground
Sweep a circle
Copy rotate
ArrayCircular *3
Union
5410.17 In reply to 5410.16
@Martin Thank you, much appreciated!
@Brian Yes, i used T-Splines Demo with Rhino Demo.
Well, i could try the Tetrus also with Surface Evolver, but i assume then it would be much thicker in some areas and then i'm not able to run it through T-Splines, because i have never tried to obtain quads out of Evolver...
Best regards
Show messages: All  1-15  16-18
