slf file format conversion
All  1-10  11-18
5410.11 In reply to 5410.10
After posting the .3dm file i thought maybe i should do a little bit with this shape. So i fired up MoI again and separated the shape and used "Inset" on each surface. Hope you like.
5410.12 In reply to 5410.11
Well it gets a thumbs up from me ... Made from the right materials you could have a rehab toy there.
Nice job futagoza
Martin
5410.13 In reply to 5410.11
How was this tetrus created? With T-Splines for Rhino?
5410.15 In reply to 5410.14
So Surface Evolver works by area or energy minimization..., which is what the tetrus is supposed to have.
Little test :)
A rounded filleted triangle on the ground
Sweep a circle
Copy rotate
ArrayCircular *3
Union
5410.17 In reply to 5410.16
@Martin Thank you, much appreciated!
@Brian Yes, i used T-Splines Demo with Rhino Demo.
Well, i could try the Tetrus also with Surface Evolver, but i assume then it would be much thicker in some areas and then i'm not able to run it through T-Splines, because i have never tried to obtain quads out of Evolver...
Best regards
Show messages: All  1-10  11-18
