Glass with water - how would....
All  1-2  3-4
541.3 In reply to 541.2
try reducing the size of the water very slightly so is is not in the exact same place as the glass but just inside it.
541.4 In reply to 541.3
That's the thing.. if you offset the water surface in a slight amount, the material won't bleed through in the rendering. You could also give the top surface of the water a little shape to simulate the affect of surface tension on water being held in a glass container.
EDITED: 11 Apr 2007 by JESSE
Show messages: All  1-2  3-4
