Glass with water - how would....
541.1
...you do it?
I created the glass and used the the curve from inside the glass to create the water volume.
...but in the renderer i get this....the water is "sticking" trough the glass.
So how would you do the modelling to get a clean result?
MfG
sk2k
541.2
Are you sure there is nothing wrong with your settings while rendering?
Check if the glass and the water geometry interfere. Post the 3dm file to check it
***There is always a better way to do things... Just find your Moment of Inspiration***
541.3 In reply to 541.2
try reducing the size of the water very slightly so is is not in the exact same place as the glass but just inside it.
541.4 In reply to 541.3
That's the thing.. if you offset the water surface in a slight amount, the material won't bleed through in the rendering. You could also give the top surface of the water a little shape to simulate the affect of surface tension on water being held in a glass container.
EDITED: 11 Apr 2007 by JESSE
