Tapered Extrude
All  1-3  4-9
5403.4 In reply to 5403.3
Hi Danny, I've set it up like this for the next beta, will this do the trick? :
I'll be out on vacation for a week here soon so the next beta will be maybe 3 or so weeks away or something like that.
5403.5 In reply to 5403.4
That'll do nicely Mr Gibson, thanks! :)
Not a problem Michael, you and your family go and have a nice vacation and enjoy yourselves..............hope you're leaving enough carrots for JoJo ;)
5403.6 In reply to 5403.5
Thanks Danny, yup JoJo will be visiting some friends where she will definitely get some carrots to munch on while we are gone.
5403.7
Just another question about Tapered Extrude, when I extrude a profile, say a simple circle, with no cap ends and select 'Tapered' the ends are capped again. Is it just for solids? Can it work with no capped ends or even open profiles creating a tapered surface?
5403.8 In reply to 5403.7
Hi Danny, yeah the geometry library function that is being used for making the tapered extrude requires a closed loop of curves as part of how it works - it constructs some planar faces for part of its calculation and that's only valid with a closed loop. So yeah that's only something that can make stuff from closed profiles currently.
Also as a side effect of the particular way it does its construction it does not have any way in it right now to turn off end caps, that's why the "Cap ends" checkbox gets hidden when you engage the tapered extrusion.
5403.9 In reply to 5403.8
Okay Thanks.
Show messages: All  1-3  4-9
