Permanent Path for Save / Open .3dm
5402.1
Pfad zum Öffnen und Speichern voreinstellen
Permanent Path for Save and Open .3dm-files
Hallo aus Frankfurt,
erst einmal vielen Dank an Michael Gibson für dieses geniale Programm.
First of all many thanks to Michael Gibson for this genius program.
Eine Frage hätte ich dann doch noch:
Kann man (z. B. in einer moi.ini) fest hinterlegen, wo die erzeugten Dateien (.3dm, .obj etc.) permanent abgespeichert bzw. geöffnet werden?
Is it possible to fix (for example in a MOI,ini) where to save / from where to open the .3dm-files?
Danke für Eure Antworten
Thanks a lot
Moritz
5402.2 In reply to 5402.1
Hi Moritz, I'm glad you like MoI!
There is nothing specially set up in MoI for that - but which operating system are you using?
In Windows for example Windows itself remembers the last directory used in the file open dialog, and will start out in that same directory the next time that you use the file dialog.
Is it that you actually want to override the default system behavior and make a fixed directory to be the one used for "Open" rather than the last used one?
Or is the problem that you're getting some other behavior than seeing the last used one?
5402.3 In reply to 5402.2
:Hi Michael, I'm glad using MoI ...
: My OS is Windows 7 Ultimate 64bit
: But this works only until a new start of Windows
: If this would solve the problem - how can I do this especially for .3dm-files?
: No, that's not the problem.
: Moritz (it's late in Germany (sunday3:05 in the morning)
5402.4 In reply to 5402.3
Hi Moritz,
I'm not sure how it would be possible to do only for .3dm files, because MoI doesn't know whether you want to open a 3DM file in particular until _after_ you've already picked the file in the file dialog.
That's because the file open command MoI allows for opening several kinds of files, not just only 3DM files...
Do you mean something like make it pay attention to when you switch the "File type" dropdown and shift to different directories when you switch that between 3DM or other file types? That would probably require some kind of fairly elaborate customization of the file dialog...
I could do something where you could set the default location for the entire "Open" command, would that work?
5402.5 In reply to 5402.3
Hi Moritz,
I think it's supposed to work past a new start of Windows too - over here it does that fine, I've tested rebooting a few times and over here Windows still remembers the last File open dialog location and sets MoI's open dialog to there.
This is with Windows 7 Professional 64-bit.
That information is stored by Windows in the system registry - do you possibly have any kind of special "registry cleaner" or special privacy filter applications running which might be intentionally discarding that information between reboots automatically for you?
5402.6 In reply to 5402.4
thanks for your help.
I've found an easy way managing my MOI-Files.
The only thing I have to do is to create a new library:
http://windows.microsoft.com/en-US/windows7/Libraries-frequently-asked-questions
Nevertheless - your MoI is an outstanding program!
Greetings from Frankfurt / Germany
Moritz
