seems so simple, but...
All  1-14  15-18
5400.15 In reply to 5400.14
Sure :) But it's only one method, surely so many other!
The key for trim anything is that ;)
A curve (surface, volume) for "trim" a volume!
With Trim = the volume stay "Open"
With Boolean Diff the volume stay "Closed"
Above i have only used a curve :)
PS A circle is sufficient even the Diff Booelan here trim the 2 sides of the piece
Just kill after the function the hole that you don't want (it's 3 clicks if it's an inner wall volume, one click if it's a surface ;)
For avoid that you can take a cylinder :)
EDITED: 16 Sep 2012 by PILOU
5400.16
I have managed to produce the model using extruded solids and fillets.
The shelling was a problem but it can be done by shelling
the base and the top section separately
Hope this of some use.
If you want the file let me know and I will post it.
Barry
Size: 337.3 KB, Downloaded: 161 times, Dimensions: 1024x600px
5400.17 In reply to 5400.16
Allright thank you Pilou! super! I feel like my knowledge has been amplified by 3. I thnk it can be amplified by another 6000, but lets go "step by step" :-)
@ Barry-H: Thank you to! It would be nice indeed to post your file, just so I can learn from it (yeah i'm addicted to knowledge :-) )
Greetz!
P
5400.18
Hi Peter,
attached is the file you requested hope it helps.
Barry
EDITED: 10 Mar 2023 by BARRY-H
Show messages: All  1-14  15-18
