space navigator
All  1-9  10-12
5391.10 In reply to 5391.9
It's more about trying to be "expert" with my 3d navigator. For instance, using the curve tool, then drawing and rotating around the sphere for various pick points! Using my spacenavigator at the same time as drawing and constructing, with 2 hands, in the 3d viewport...
But it is a bit unconventional, and not a normal workflow for me. Hence I didnt want to push for totally figuring it out. I was looking to see if it was a simple explanation found with some understanding of the underlying process.
It may very well be limited to "only my system", in which case, a bunch of time doesnt need to be wasted on why, what etc. on your end.
5391.11 In reply to 5391.10
Hi Burr,
Does that particular one actually work ok for you though? The curve tool is in a drawing command, not selection mode...
5391.12 In reply to 5391.11
Yes, that was the revalation during this discussion.... My first impression just came at initial launch after updating my SN device drivers..... So, outside of a command, I just need to flick the mouse out of the viewport....... :)
Show messages: All  1-9  10-12
