first test with moi of torolf
 1-9  10-29  30-49  50-56
539.50 In reply to 539.48
Pilou -I don't know this workaround.
Works fine, many thanks...
539.51 In reply to 539.49
> You could use the Control Point spline tool to redraw
> each cell at their control points and then may offset
> the spline a bit.
Yeah judging by the generated shape, I'm pretty sure that this was the technique used to generate the curves.
539.52
Hi all :)
no help more from me. why:
http://www.maxon.net/uploads/pics/TopMod_Star_Corona2_18.jpg
torolf
539.53 In reply to 539.11
Hello all ( specially TOROLF),
I would like to know the easiest way to create the surface shown (highlighted yellow) in the picture of post 539.11 without holes.
539.54 In reply to 539.53
Hi Psygorn, often times using sub-d modeling in a polygon modeling program is the easiest way to make smooth blended branching structures.
One way that you could try in MoI though is by setting up curves like this:
Extrude to make suraces:
Hide curves and select edges and use Construct > NSided to make an n-sided patch there:
Then mirror:
3DM model file attached.
539.55 In reply to 539.54
Hello and thank you, Michael;
I gave it a try before seeing your reply and I came up with the results below on my own. however, I want to ask can I be sure that the transition between red and green surfaces is done smoothly?
I mean the blue edge would be smooth?
539.56 In reply to 539.55
Hi Psygorn, in your model the blue edge is definitely not smooth. To get a better look at it, assign all surfaces to "Default" style and then export to an .obj file and you can get this display:
You can set up a shortcut key for Space having:
SaveAs c:\test.obj
as a shortcut for getting this kind of display easily.
It's difficult in NURBS surfacing to make a smooth surface patched in between an odd number of open edges like you're trying to do there. That's one of the strengths of sub-d modeling that it can more easily blend between things like that.
Show messages:  1-9  10-29  30-49  50-56
