File path on a Mac
5388.1
I am trying to export a .obj using a hot key in the OS X version and have run into a snag. I am not sure how to write the file path.
This is what I have so far.
script:moi.geometryDatabase.fileExport( 'user/me/desktop/test.obj' );
It gets to the meshing stage but doesn't save the file. I think is has something to do with the file path I am using. Any help would be appreciated.
-Shane
5388.2 In reply to 5388.1
Hi Shane, an absolute file path on the Mac should start with the / character, and also the regular directory for users is named 'Users', not just 'user' like you've written there.
So for instance on my machine where my user name is michael to write a file to my user directory would look like this:
script:moi.geometryDatabase.fileExport( '/Users/michael/test.obj' );
The fileExport() method will write just the selected objects to the file so you will need to make sure you have a selection first before calling that.
If you want to write out everything regardless of selection then use the saveAs method instead, like: moi.geometryDatabase.saveAs( '/Users/michael/test.obj' );
Hope this helps!
5388.3 In reply to 5388.2
Perfect! Silly "s" who knew computers were so picky?
As always, thanks for the awesome support Michael.
5388.4 In reply to 5388.3
No problem shane!
