Hard one: Strawberry with flow...
All  1  2-5
5380.2 In reply to 5380.1
Buy a punnet whilst they are in season look down on one from above and free hand the shape, then rorate and view from sides, unless you have callipers to measure it, and do this 5 or 6 times, split the top curve with intersecting profile curves and then network it piece by piece. Then you can apply you routine per piece.
Martin
5380.3 In reply to 5380.1
Hi Torsten,
This may help: http://moi3d.com/forum/index.php?webtag=MOI&msg=4549.1
though only academically.
The way you're doing it will cause the pattern to pinch near the poles.
My big suggestion is to avoid the pole areas with and objects (degenerate points/sides). The Flow command has difficulty in those areas.
If you are able to wrap the pattern in the majority of the surface area, you can always use other methods to complete the remaining area.
5380.4 In reply to 5380.1
Hi torsten,
> when i try to use a revolved object it either produces garbage, or no result at all.
Could you please post the 3DM model file with the objects that produce the garbage or non-result so I can test with them over here?
5380.5 In reply to 5380.1
Worked on a Raspberry a while back, with a little different technique:
http://moi3d.com/forum/index.php?webtag=MOI&msg=5178.1
First you have to count how many seeds in a strawberry :-)
EDITED: 9 Sep 2012 by BEMFARMER
Show messages: All  1  2-5
