New version of BRL cad
All  1-2  3-6
5334.3 In reply to 5334.2
Not yet ! I am a little affraid to not no more UI views somewhere :)
and this one is terrifying me :)
EDITED: 18 Aug 2012 by PILOU
5334.4
I played around with BRL-CAD about 2/3 years ago. A very complicated design interface (everything was command line input) and drawing something as simple as a die (cube with fillets) was quite a lot of work. On top of that it is not parametric which makes it impractical for day-to-day design use on a professional level. Add to that tthe fact that it could export as iges, step, etc.
I'll try it again, but just for the fun of it. For the youngsters in the CAD community it would be great to learn it as it will teach them A LOT about the early developement of CAD programs.
5334.5 In reply to 5334.4
<< about 2/3 years ago (everything was command line input)>>
If you try it tell me if it's always the case! :)
5334.6 In reply to 5334.5
>>If you try it tell me if it's always the case! <<
I'm actually swamped with work at the moment. That tank is misleading though. No way was that design in BRL-CAD. You'd need like two years to do it...
Show messages: All  1-2  3-6
